brenthutch 444 #751 July 18, 2019 Yes it is true that warm air can hold more moisture, it is also true that that moisture laden warm air cannot produce snow. (You need cold to make snow) Share this post Link to post Share on other sites
DJL 235 #752 July 18, 2019 4 minutes ago, brenthutch said: Yes it is true that warm air can hold more moisture, it is also true that that moisture laden warm air cannot produce snow. (You need cold to make snow) Such as when it's driven South from the Arctic Circle. https://www.forbes.com/sites/startswithabang/2019/01/30/this-is-why-global-warming-is-responsible-for-freezing-temperatures-across-the-usa/#bbed3d2d8cf8 "While a small but vocal minority of people might use the faulty logic of, "it's cold where I am, therefore global warming isn't real," even schoolchildren know that weather isn't climate." Share this post Link to post Share on other sites
JerryBaumchen 1,493 #753 July 18, 2019 2 hours ago, brenthutch said: You forgot about the record breaking/ road closing snow out West! Hi Brent, What part of 'out West' are you referring to? I live about 70 miles east of the Pacific Ocean & it is 74* here. I just checked. Jerry Baumchen Share this post Link to post Share on other sites
kallend 2,230 #754 July 19, 2019 6 hours ago, brenthutch said: Yes it is true that warm air can hold more moisture, it is also true that that moisture laden warm air cannot produce snow. (You need cold to make snow) Wrong. You aren't as clever as you think you are. Share this post Link to post Share on other sites
billvon 3,173 #755 July 19, 2019 7 hours ago, brenthutch said: Yes it is true that warm air can hold more moisture, it is also true that that moisture laden warm air cannot produce snow. (You need cold to make snow) ?? Warm air over water + warm water = lots of evaporation = warm wet air Wet air rises due to orographic lift = cold wet air Cold wet air = snow This is weather 101. Even found a picture of it. Share this post Link to post Share on other sites
JoeWeber 3,026 #756 July 19, 2019 3 hours ago, kallend said: Wrong. You aren't as clever as you think you are. John, that was rude. He was talking to his audience, not you. Share this post Link to post Share on other sites
DJL 235 #757 July 19, 2019 (edited) 10 hours ago, billvon said: ?? Warm air over water + warm water = lots of evaporation = warm wet air Wet air rises due to orographic lift = cold wet air Cold wet air = snow This is weather 101. Even found a picture of it. Basically how you can surf in the morning and go skiing in the afternoon on the West Coast. I do think he's referring to an earlier snow event that was caused by an artic cyclone release but he doesn't provide specifics lest he not only be proven conceptually wrong but also specifically wrong. Edited July 19, 2019 by DJL Share this post Link to post Share on other sites
brenthutch 444 #758 July 19, 2019 Y’all might want to bone up on a little sumthin I like to call “Dew Point” before getting all nasty w me. Share this post Link to post Share on other sites
DJL 235 #759 July 19, 2019 19 minutes ago, brenthutch said: Y’all might want to bone up on a little sumthin I like to call “Dew Point” before getting all nasty w me. Sure thing. Point to the specific snow storm you're referring to and tell us what it proves. Share this post Link to post Share on other sites
brenthutch 444 #760 July 19, 2019 I was referring to the two feet of snow Colorado got on the first day of summer. I’m guessing someone will tell me this http://maritimebulletin.net/2019/07/19/icebreaker-turned-back-encountering-heavy-ice-in-ice-free-arctic/ is from global warming as well. Share this post Link to post Share on other sites
DJL 235 #761 July 19, 2019 (edited) 11 minutes ago, brenthutch said: I was referring to the two feet of snow Colorado got on the first day of summer. I’m guessing someone will tell me this http://maritimebulletin.net/2019/07/19/icebreaker-turned-back-encountering-heavy-ice-in-ice-free-arctic/ is from global warming as well. Why should someone say it's global warming? Even a child knows the difference between the weather and the climate. Sure, severe and odd weather events can be caused by global warming, per my artic cold air blast example. So...what are YOU saying it proves? Edit: Ahhh, I see you've turned your story from snow in the US NW to an ice breaker that found ice in the Artic Circle. Ok...what are you saying either proves? Edit2: And not that you actually care about the actual findings of the overall artic ice sheet: https://www.nasa.gov/feature/goddard/2019/arctic-sea-ice-2019-wintertime-extent-is-seventh-lowest Edited July 19, 2019 by DJL Share this post Link to post Share on other sites
brenthutch 444 #762 July 19, 2019 Seventh lowest, wow that is terrifying! Where do I sign up for a carbon tax? BTW I didn’t change my story, I added to it. Share this post Link to post Share on other sites
DJL 235 #763 July 19, 2019 (edited) 54 minutes ago, brenthutch said: Seventh lowest, wow that is terrifying! Where do I sign up for a carbon tax? BTW I didn’t change my story, I added to it. And since you're a smart guy I'm sure you understand the difference between extent and volume. As that 7th lowest extent article describes, the volume is actually seeing a permanent decrease. Here's the closest narrative to raw data available: http://psc.apl.uw.edu/research/projects/arctic-sea-ice-volume-anomaly/ And since you're keen on suggesting people eat crow because for some reason the most recent reading has to the the worst in order for a point to be made here's a graph using the actual raw data showing both the trend in volume over the last 40 years AND the fact that 2019 is in fact the worst for ice volume loss. As in the most recent reading of ice volume is the lowest in (recent) history. Want to switch back to talking about snow storms in the North West? That's probably an easier one for you since you can just say, "Look! Snow in April!" as if that means something. Edited July 19, 2019 by DJL Share this post Link to post Share on other sites
kallend 2,230 #764 July 25, 2019 Paris (France) is pretty warm today. All-time record warm. Probably just a hoax. Share this post Link to post Share on other sites
Coreece 190 #765 July 25, 2019 10 minutes ago, kallend said: Paris (France) is pretty warm today. All-time record warm. Ugh, I can smell it all the way over here. Share this post Link to post Share on other sites
kallend 2,230 #766 July 25, 2019 TWO record breaking heat waves in a month. Nothing to see here, move along please. By Linda Givetash LONDON — Britain is bracing for its hottest day in recorded history as a heat wave raises concerns for health and wildfire risks across western Europe. The United Kingdom’s Met Office issued a warning that Thursday could see the 101.3-degree record set in August 2003 shattered with forecasts of a high of 102.2 degrees. An influx of hot air from North Africa is triggering the sky-high temperatures, similar to last month’s record heat wave that hit much of central and western Europe Share this post Link to post Share on other sites
kallend 2,230 #767 July 27, 2019 So the hottest weather ever recorded in France, the United Kingdom, Belgium, the Netherlands and Germany yesterday. Even Bergen, Norway, went over 90F. Meteorologists are forecasting record ice-melt in Greenland this summer. NOAA reported that the 12 months from July 2018 to June 2019 were the wettest ever recorded in the USA. Even farmers in Trumpland are beginning to realize that climate change may not be a hoax after all as they look over their flooded fields. Share this post Link to post Share on other sites
tonyhays 86 #768 July 27, 2019 Not to mention huge parts of Australia are in drought with water restrictions being in place in NSW since June 1st http://www.bom.gov.au/climate/drought/ Share this post Link to post Share on other sites
brenthutch 444 #769 July 29, 2019 Floodroughts are my favorite oxymoron. LOL! Share this post Link to post Share on other sites
brenthutch 444 #770 July 29, 2019 On 7/27/2019 at 10:10 AM, kallend said: NOAA reported that the 12 months from July 2018 to June 2019 were the wettest ever recorded in the USA. Don’t tell BillV, he promised us droughts. Share this post Link to post Share on other sites
DJL 235 #771 July 29, 2019 12 minutes ago, brenthutch said: Don’t tell BillV, he promised us droughts. Can you point to where BillV said there would be droughts within these 12 months? Share this post Link to post Share on other sites
brenthutch 444 #772 July 29, 2019 14 minutes ago, DJL said: Can you point to where BillV said there would be droughts within these 12 months? “Higher temps cause droughts. Basic earth science” BillV Share this post Link to post Share on other sites
DJL 235 #773 July 29, 2019 9 minutes ago, brenthutch said: “Higher temps cause droughts. Basic earth science” BillV Looks like there's been rain where it's been cool and less rain where it's been hot: https://www.ncei.noaa.gov/news/national-climate-201905 Share this post Link to post Share on other sites
billvon 3,173 #774 July 29, 2019 1 hour ago, brenthutch said: Don’t tell BillV, he promised us droughts. When you have to lie to make your points, your points are probably pretty sad to begin with. Share this post Link to post Share on other sites
kallend 2,230 #775 July 29, 2019 23 minutes ago, billvon said: When you have to lie to make your points, your points are probably pretty sad to begin with. Hey, Trump does it on a daily basis. Share this post Link to post Share on other sites
