Guest #1 Posted June 17, 2019 (edited) All, I've had a Parasport Italia Z1 for about 20 years. All the foam insulation in the neck curtain has broken down, and there is brown grit coming out of the drawstring holes. Does anyone replace worn-out neck curtains in the Z1? The liner pads seem to be okay....thanks! Edited June 17, 2019 by Guest Quote Share this post Link to post Share on other sites
sundevil777 102 #2 June 17, 2019 3 hours ago, markharju said: All, I've had a Parasport Italia Z1 for about 20 years. All the foam insulation in the neck curtain has broken down, and there is brown grit coming out of the drawstring holes. Does anyone replace worn-out neck curtains in the Z1? The liner pads seem to be okay....thanks! This company used to advertise on their website that they would replace the skirt, maybe they still do. I tried the new skylight lens, and the weird distortion they warn of was more distracting than I thought it would be and is not worth trying. https://www.unfeathered.com/clearance-z-1 Quote Share this post Link to post Share on other sites
sundevil777 102 #3 June 17, 2019 8 minutes ago, sundevil777 said: This company used to advertise on their website that they would replace the skirt, maybe they still do. I tried the new skylight lens, and the weird distortion they warn of was more distracting than I thought it would be and is not worth trying. https://www.unfeathered.com/clearance-z-1 If you click on accessories-helmet additions, then scroll down, there is a link to service/refurbish Z1 helmet $40 for the skirt installed: https://docs.wixstatic.com/ugd/18d9e0_dc34ee5fa156465b999714d9dfacd29a.pdf Quote Share this post Link to post Share on other sites
