Guest #1 Posted July 22, 2020 On the climb to altitude the (new to skydiving) pilot driving our 182 insisted that we were at 1500m (~4921ft) by pointing at the alti on his console and that I should get out for my hop & pop, but a quick look at everyone else's altimeters showed that we were at less than 762m (~2500ft). It took some convincing to get him to go to 1500m (~4922ft) AGL and he eventually settled on ~1219m (~4000ft) AGL. Maybe the pilot's altimeter was set to MSL (DZ elevation is 1223ft / 372m)? This was new to me despite nearly 25 years of jumping. Posting in the interest of safety and learning whether anyone else has experienced this kind of altitude dispute with a pilot. Thanks! Quote Share this post Link to post Share on other sites
pchapman 279 #2 July 22, 2020 Sounds something like that, having the alti on standard above-sea-level figures. (Another possibility for having the issue in general, although not in your particular case, is zeroing the alti wrong, missing that it is set at -1000 feet instead of 0 feet. That's for altis in feet where one full revolution of the big hand = 1000 feet.) Since it is vital for pilots to report to air traffic control the proper way, above MSL, I've seen jump planes with a skydiving alti stuck to the instrument panel so that can be zeroed on the ground and the pilot doesn't have to do the mental math all the time either for ATC or skydivers. I had the same problem once when dropping static line students years ago. I couldn't convince the pilot he was wrong, so I just asked him for an extra thousand feet of altitude for these particular students. Which he gave me, no problem, putting us slightly above our desired altitude instead of at an altitude below what's allowed... Quote Share this post Link to post Share on other sites
gowlerk 2,251 #3 July 22, 2020 (edited) 1 hour ago, markharju said: On the climb to altitude the (new to skydiving) pilot driving our 182 insisted that we were at 1500m (~4921ft) by pointing at the alti on his console and that I should get out for my hop & pop, but a quick look at everyone else's altimeters showed that we were at less than 762m (~2500ft). It took some convincing to get him to go to 1500m (~4922ft) AGL and he eventually settled on ~1219m (~4000ft) AGL. Maybe the pilot's altimeter was set to MSL (DZ elevation is 1223ft / 372m)? This was new to me despite nearly 25 years of jumping. Posting in the interest of safety and learning whether anyone else has experienced this kind of altitude dispute with a pilot. Thanks! In aviation every aircraft altimeter is set to measure MSL altitude. It's pretty clear that your new pilot missed the part of the training where he should have learned that his job is to take skydivers to their assigned altitude above ground level. Mostly they do the math to figure out what that is in MSL altitude. Edited July 22, 2020 by gowlerk Quote Share this post Link to post Share on other sites
billvon 3,075 #4 July 22, 2020 6 hours ago, markharju said: On the climb to altitude the (new to skydiving) pilot driving our 182 insisted that we were at 1500m (~4921ft) by pointing at the alti on his console and that I should get out for my hop & pop, but a quick look at everyone else's altimeters showed that we were at less than 762m (~2500ft). It took some convincing to get him to go to 1500m (~4922ft) AGL and he eventually settled on ~1219m (~4000ft) AGL. Maybe the pilot's altimeter was set to MSL (DZ elevation is 1223ft / 372m)? This was new to me despite nearly 25 years of jumping. Aircraft in the US set their altimeters to MSL not AGL. (That's why barometric pressure readings are important, so everyone flying in airspace together can agree on what MSL altitude is.) Quote Share this post Link to post Share on other sites
Guest #5 July 24, 2020 On 7/22/2020 at 6:54 PM, billvon said: Aircraft in the US set their altimeters to MSL not AGL. (That's why barometric pressure readings are important, so everyone flying in airspace together can agree on what MSL altitude is.) Because this took place at a DZ in Germany, I think it's safe to assume that a default MSL setting is present there as well (probably an ICAO standard or something - I dunno, I don't drive 'em, I just jump out of 'em). What I don't get is why the barometric offset was not put in the alti beforehand to get AGL (isn't the pilot supposed to adjust the barometric setting on the alti to get a zero AGL reference for local conditions, or is that optional? This is VFR below 14k after all; or is the pilot expected to take the local elevation into account when looking at the alti? That seems a confusing way to do things) - anyway, thanks for the responses. Quote Share this post Link to post Share on other sites
mark 107 #6 July 24, 2020 4 hours ago, markharju said: What I don't get is why the barometric offset was not put in the alti beforehand to get AGL (isn't the pilot supposed to adjust the barometric setting on the alti to get a zero AGL reference for local conditions, or is that optional? This is VFR below 14k after all; or is the pilot expected to take the local elevation into account when looking at the alti? If the pilot has only one altimeter, he can set it to MSL and do the mental calculation to get AGL for skydivers, or he can set it to AGL and do the mental calculation to talk to ATC or other airplanes. ATC and collision avoidance are generally more urgent and the consequences of miscalculation more immediate, so setting to MSL is more common. What I don't get is why anyone is arguing with the pilot at all. If you need more altitude, just decline to jump and ask for a higher pass. Quote Share this post Link to post Share on other sites
JoeWeber 2,836 #7 July 25, 2020 (edited) On 7/22/2020 at 6:35 AM, markharju said: On the climb to altitude the (new to skydiving) pilot driving our 182 insisted that we were at 1500m (~4921ft) by pointing at the alti on his console and that I should get out for my hop & pop, but a quick look at everyone else's altimeters showed that we were at less than 762m (~2500ft). It took some convincing to get him to go to 1500m (~4922ft) AGL and he eventually settled on ~1219m (~4000ft) AGL. Maybe the pilot's altimeter was set to MSL (DZ elevation is 1223ft / 372m)? This was new to me despite nearly 25 years of jumping. Posting in the interest of safety and learning whether anyone else has experienced this kind of altitude dispute with a pilot. Thanks! I think your dispute is with the DZO. You might kindly ask if they would be so good as to actually train the pilots in the future. You might point out, as reasonably as possible, that knowing how high above the ground ones jumpers are while in flight is a very important part of jump piloting. Edited July 25, 2020 by JoeWeber 2 Quote Share this post Link to post Share on other sites
Guest #8 July 27, 2020 On 7/24/2020 at 3:23 PM, mark said: If the pilot has only one altimeter, he can set it to MSL and do the mental calculation to get AGL for skydivers, or he can set it to AGL and do the mental calculation to talk to ATC or other airplanes. ATC and collision avoidance are generally more urgent and the consequences of miscalculation more immediate, so setting to MSL is more common. What I don't get is why anyone is arguing with the pilot at all. If you need more altitude, just decline to jump and ask for a higher pass. The airfield in question (Bitburg) is not exactly remote. Spangdahlem AB is pretty close (~9km apart) and houses fast-movers so I'm sure there is positive ATC in the area. Thanks to all for comments. Quote Share this post Link to post Share on other sites
fcajump 164 #9 August 4, 2020 (edited) On 7/24/2020 at 9:23 AM, mark said: If the pilot has only one altimeter, he can set it to MSL and do the mental calculation to get AGL for skydivers, or he can set it to AGL and do the mental calculation to talk to ATC or other airplanes. ATC and collision avoidance are generally more urgent and the consequences of miscalculation more immediate, so setting to MSL is more common. What I don't get is why anyone is arguing with the pilot at all. If you need more altitude, just decline to jump and ask for a higher pass. (understanding that the OP was not in the USA, just for sake of discussion) IIRC - In the US - 91.121 Altimeter settings. (a) Each person operating an aircraft shall maintain the cruising altitude or flight level of that aircraft, as the case may be, by reference to an altimeter that is set, when operating— (1) Below 18,000 feet MSL, to— (i) The current reported altimeter setting of a station along the route and within 100 nautical miles of the aircraft It is waverable for airshows and low-level aerobatics where you can set it to AGL. But you also need the pilot to understand that jumpers (except those planning a water landing) don't care flip about the sea level... we do care very much about the ground under us, and how far that is... JW Edited August 4, 2020 by fcajump Quote Share this post Link to post Share on other sites
JohnMitchell 16 #10 November 9, 2020 (edited) On 7/24/2020 at 2:05 AM, markharju said: Because this took place at a DZ in Germany, I think it's safe to assume that a default MSL setting is present there as well (probably an ICAO standard or something - I dunno, I don't drive 'em, I just jump out of 'em). What I don't get is why the barometric offset was not put in the alti beforehand to get AGL (isn't the pilot supposed to adjust the barometric setting on the alti to get a zero AGL reference for local conditions, or is that optional? This is VFR below 14k after all; or is the pilot expected to take the local elevation into account when looking at the alti? That seems a confusing way to do things) - anyway, thanks for the responses. All aircraft altimeters are adjusted to read MSL. Pilots should adjust their altimeters to read the field elevation before take off, not zeroing them like skydivers do. Pilots are supposed to be able to do the math in their head. It's not confusing to an experienced jump pilot. Jump altitude + Field elevation = MSL altitude for jump run. Sounds like you had a very new or very stupid jump pilot. If you were planning 5000' and you only got 2500', I would guess your field elevation to be 2500', not the 1223' you posted. Overall just a total screwup. IDK the range of adjustment on aircraft altimeters, but 1" of Hg = 1,000' of altitude. I used to jump at 5000' above sea level (Utah) and I doubt if the plane's altimeter could have been adjusted to barometer setting of 24.92. (std. being 29.92" Hg). Edited November 9, 2020 by JohnMitchell Quote Share this post Link to post Share on other sites
JohnMitchell 16 #11 November 9, 2020 On 7/24/2020 at 6:23 AM, mark said: What I don't get is why anyone is arguing with the pilot at all. If you need more altitude, just decline to jump and ask for a higher pass. Because the pilot thought he was doing a great job, and he wasn't. Quote Share this post Link to post Share on other sites
macau 6 #12 November 9, 2020 Just give the pilot a skydive altimeter that he can set to zero. Reference this for jump run, set aircraft altimeter to barometric pressure, reference this with ATC. Question-you are jumping at DZ that is 2,500 feet higher then your take off airport how do you set your altimeter???? Quote Share this post Link to post Share on other sites
obelixtim 150 #13 December 4, 2020 This is jump pilot 101 stuff. Major problem can occur with AADs if the pilot gets it wrong. Having said that, just use the finger pointing upwards to tell him you want more. And its up to you to decide when you want to depart the A/C, not him. (unless of course someone has pressed the "wings off" button.) Quote Share this post Link to post Share on other sites
WV177RG 19 #14 December 4, 2020 [Classic Gary Larson/Far Side cartoon] I've jumped several (unpressurized) aircraft in which altimeters were mounted on the aft bulkhead for skydiver reference. Since no one was assigned to ensure they were zeroed before takeoff--assuming we were taking off and landing at the same field elevation--I always zeroed the cabin altimeter during boarding, then checked against my own on the climb to altitude. Specialty jumps: check with the pilot before takeoff. Flying gliders years ago, we zeroed our altimeters like skydivers for local flights (AGL-Above Ground Level) but used the current barometric pressure setting (MSL-Mean Sea Level) for cross country flights. FAA balloon flying handbook: "Figure 6-10. The altimeter should be set to barometric pressure*, if available, or to the field elevation.**" *MSL/**AGL Quote Share this post Link to post Share on other sites
