3 3
maggyrider
From skydiving to paragliding/speedflying: Field report, part 1
Intro
As there are not a lot of ressources regarding a transition from skydiving to paragliding/speedflying available online, I decided to share my experiences and impressions in this post here. Even if you are not planning to get into paragliding yourself, it might still give some interesting insights. If you like, I can keep you updated on my journey.
About my skydiving background
Originally from Austria, I started skydiving in southern Germany back in August 2012 and got pretty hooked on it. After spending every weekend at the dropzone for about a year, I decided to quit my regular job, move to the dropzone and pursue a career there, although I always had to support it with at least a part time "normal" job. Living off skydiving alone is almost impossible within Germany.
After about two years (as soon as legally possible) I got my coach and tandem instructor rating. I was able to earn money with skydiving from that point on, mainly doing videos, tandems and coaching jumps. My AFF rating followed soon after. My favourite discipline in skydiving has always been canopy piloting, why I invested lots of time, money and effort into that.
I quit skydiving in the beginning of 2020 as I was starting to burn out after 7 seasons of 7-day-weeks during the summer and moved back to my origin in the Alps of Austria at the beginning of this year. Alltogether I did about 3500 jumps of which about 2000 have been on solo-canopies.
My canopy progression was:
* PD 170  (~150 jumps)
* Pilot 150 (~150 jumps) - started working on high-performance landings with that canopy
* Pilot 132 (~200 jumps)
* Katana 120 (~200 jumps)
* Velocity 96 (~300 jumps)
* Valkyrie 84 (~1.000 jumps) - loaded with up to 35lbs of extra lead (total exit weight around 220lbs) (sample landing)
Do not take my personal path as advice for your own downsizing. I went through some downsizing steps rather fast, but keep in mind that I did many of these jumps in shorter timespans than many other people and always had direct mentoring from more experienced pilots available. In retrospective I have to say, that the step from the Pilot 132 to the Katana 120 was the most challenging.
My paragliding experience until now
I started my training at Cloudbase, a professional, commercial paragliding school in Zell am Ziller (Tyrol, Austria) - huge recommendation by the way - last Saturday and completed my final exam yesterday. Usually training takes a bit longer (40 flights) but due to local regulations a shortcut for licensed skydivers is possible (15 flights, although practically not appropriate in many cases).
Theoretical instruction is easy, but covers topics that many skydivers have likely never had any contact with. It might have helped that I also hold a commercial pilot license for airplanes and have quite some knowledge regarding meteorology and basic aerodynamics, but I doubt that my skydiving experience gave me an advantage in that area.
During training (and some test flights today) I had the chance to fly the following paragliding wings (surface area in brackets although less relevant):
* Mescal S (240 sqft)
* Masala S (235 sqft)
* Susi 23 (213 sqft)
* Susi 21(190 sqft)
* Kode P 18 (173 sqft)
* Tonic 2 S (172 sqft)
How do paragliding wings compare to skydiving canopies?
I was surprised how much performance even large student paragliding wings offered in comparison to skydiving canopies for students.
While a skydiving canopy for students (and to be honest - also most intermediate skydiving canopies) allows the pilot to hang in the harness like a bag of water and yank on the steering lines without any requirement for sensitivity, a paragliding wing requires immensely more coordinated inputs by harness and brakes to achieve an acceptable amount of control. I suppose a docile student paragliding wing would likely still not kill you, but it will be a very uncontrolled ride, if you fly it the same way a skydiving canopy allows you to fly.
Techniques required to fly real high-performance skydiving canopies transition very well to paragliding. From the first flight on paragliding felt very natural and I had the feeling of having a good amount of control over the wing. I got lots of compliments to be the very first skydiver at the school with sensitivity for brake inputs.
Aside from techniques like doing big ears, that are not used/available in skydiving, a huge difference is the possibility of (unintentionally) inducing extended rolling and pitching oscillations and the inputs required to stop these oscillations. Standard skydiving canopies do not really require such inputs and will quickly self stabilize (or at least keep the oscillations low). High-performance skydiving canopies require such inputs but still stabilize quicker than paragliding wings.
While angle-of-attack control is not necessarily required to safely fly a skydiving canopy, like it is on a paragliding wing, it certainly allows much better flight path control even on less performant skydiving wings (Did you ever feel your controls become "mushy" after recovering from a turn input? Surprise! There's ways around that...). Some skydiving pilots might bring that skill, some might not.
Paragliding wings are a lot easier to flare than their skydiving counterparts. I did not see a lot of really bad flares during the course on my coursemates without any pre-experience. That is likely due to the much lower sink rate and more lift that paragliding wings provide. I would not expect any skydiver to have much trouble correctly flaring a paragliding wing.
Paragliding wings seem a lot less critical regarding low turns. While even very docile student skydiving canopies react with a good amount of dive to any turn, I have seen safe turns at heights that sent shivers down my former skydiving instructor spine during the past week. There are other dangers that come with paragliding wings, but the risk coming with low turns seem a lot lower with paragliding. I do not have any numbers on that feeling, so take it with a grain of salt.
Conclusion
I have a hand full of paragliding flights by now, so my opinion might either be false or have to be revised by myself in the future.
High-performance canopy flying experience transitions very well to paragliding and should allow you to feel comfortable on a paragliding wing quickly. Controls are different but follow very similar principles. If you got the feeling for a high-performance skydiving canopy, you will likely have the feeling for a paragliding wing. At least a docile one (like to ones I used to fly during the past week) and at least in my case.
I doubt that limited, other skydiving experience will give you a huge advantage on paragliding. Some things might feel similar, certainly taking away a good amount of stress. Some of your habits might be very counter-productive. And it is very well possible that you will have to seriously extend your "toolbox of canopy control".
Recommendations
In any case, do not assume that you know how to fly a paragliding wing, because you know how to control a skydiving canopy. It's different.
I for my part decided to go with the Tonic 2 S for now. It's very slow in comparison to the Valkyrie 84 I used to fly, but it still behaves reasonably agile and I have the feeling that I got a good amount of work to do until I can fly it perfectly to its limits. It outperforms similarly sized skydiving canopies by far. Speedflying is my goal, but I do not see any reason to rush it.
Doing some paragliding training could be a good addition to becoming a great skydiving canopy pilot. I can see paragliding skills and knowledge transition extremely well to skydiving canopy control, if you already bring some skydiving experience. Paragliding training is super cheap in comparison to skydiving. And it's a huge amount of fun.
  • Like 7
3 3
