motorheaddown 0 #1 June 25, 2014 I just sat through a high altitude training class sponsored by the military (I'm a civilian), and they claim pulling at higher altitudes results in higher G-loading at opening due to increased fall rate. I don't buy it. Dynamic pressure (i.e. what the body feels) is constant throughout the jump even though terminal velocity changes as a function of altitude. Consequently, I'd think the canopy should open normally with the same G-loading at any altitude once terminal velocity is reached. Am I right? Thanks, -scott Quote Share this post Link to post Share on other sites
skydiverek 63 #2 June 25, 2014 Read from THIS post, down: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4640744#4640744 Quote Share this post Link to post Share on other sites
diablopilot 2 #3 June 25, 2014 Your instructors are correct. I've seen a 30,000 ft static line jump and the openings were brutal enough to knock the participants out.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
faulknerwn 38 #4 June 25, 2014 It was actually an issue on the CRW world record jumps too. The guys pulling highest (with bailout oxygen) at 18k if I remember right had to get solid sliders on their canopies to assist with the openings.. Quote Share this post Link to post Share on other sites
motorheaddown 0 #5 June 25, 2014 skydiverekRead from THIS post, down: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4640744#4640744 Interesting... Looks like I'm wrong. Thanks, -scott Quote Share this post Link to post Share on other sites
Deimian 43 #6 June 26, 2014 skydiverekRead from THIS post, down: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4640744#4640744 Do we know if the stated values in that post are true? In physics many many times things do not change linearly. So I am wondering if is true that if freefall is X times faster at altitude Y, then canopy descend rate is also X times faster. I guess it is. I am also wondering if opening times will be the same, since air density is much lower, and fill the canopy cells with enough molecules might require more time. My assumption is that the extra time needed (at a constant speed) to inflate a canopy at a high altitude is compensated by the fact that the fall speed is not the same. To summarize, I think the post is correct, but I am not an expert in fluid dynamics, and I would like to know if there have been experiments about that, or if an expert in fluid dynamics can confirm these assumptions. Quote Share this post Link to post Share on other sites
excaza 1 #8 June 26, 2014 DeimianI am also wondering if opening times will be the same, since air density is much lower, and fill the canopy cells with enough molecules might require more time. My assumption is that the extra time needed (at a constant speed) to inflate a canopy at a high altitude is compensated by the fact that the fall speed is not the same. The air density is lower but you're falling faster. At terminal, your dynamic pressure (and therefore indicated airspeed) is going to be the same, so you're still moving by the same amount of molecules in that time. However, your true airspeed is higher so you have more kinetic energy to bleed off during the opening process resulting in a higher total shock. QuoteTo summarize, I think the post is correct, but I am not an expert in fluid dynamics, and I would like to know if there have been experiments about that, or if an expert in fluid dynamics can confirm these assumptions. There has been a good amount of testing done, starting with the Army & Air Force post WWII through the 60s-70s with NASA joining in for the latter portion with their development of canopies for various spacecraft, landers & crew modules. I don't have specific references on hand but if I get a chance I can see if some of the historical work is online somewhere. Quote Share this post Link to post Share on other sites
pchapman 279 #9 June 26, 2014 excaza I don't have specific references on hand but if I get a chance I can see if some of the historical work is online somewhere. A couple sources are the Irvin Recovery Systems Design Guide AFFDL-TR-78-151, and the Parachute Recovery Systems Design Manual by Theo Knacke for the US military. Both are online... somewhere, and have been mentioned on dz. Attached is a pdf I made of the Altitude effect section of the more recent Knacke manual. It isn't ideal for our purposes but gives some idea of altitude issues. The rate of increase of opening force with altitude does depend on the design of the parachute, and whether the load is light (like a person) or heavy (like a bomb) relative to the size of the parachute. The research shown only applies to unreefed round canopies. I would imagine that the reefing of ram air parachutes would decrease the sensitivity to altitude, but would not change the basic principles (like higher true speed and energy when up high) or that higher altitude openings get harder. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #10 June 26, 2014 Deimian Do we know if the stated values in that post are true? In physics many many times things do not change linearly. So I am wondering if is true that if freefall is X times faster at altitude Y, then canopy descend rate is also X times faster. I guess it is. Original models were with high drag/low lift round canopies, so that assumption is pretty defensible. Even square canopies, as they are deploying with brakes set, are at an angle of attack way past their stall AOA, and are therefore acting mostly as drag devices, not lift generating airfoils. Quote I am also wondering if opening times will be the same, since air density is much lower, and fill the canopy cells with enough molecules might require more time. My assumption is that the extra time needed (at a constant speed) to inflate a canopy at a high altitude is compensated by the fact that the fall speed is not the same. To summarize, I think the post is correct, but I am not an expert in fluid dynamics, and I would like to know if there have been experiments about that, or if an expert in fluid dynamics can confirm these assumptions. My explanation was qualitative, but not exactly quantitative. Parachute opening rate seems to be related to indicated airspeed, so the "low density" argument is countered by the "high true airspeed" factor. I'm certainly not a fluid dynamic expert, but have read of the hard openings due to premature deployments on HALO jumps. The physics were explained in that article and seem very common sense to me too. Quote Share this post Link to post Share on other sites
Deimian 43 #11 June 27, 2014 pchapman*** I don't have specific references on hand but if I get a chance I can see if some of the historical work is online somewhere. A couple sources are the Irvin Recovery Systems Design Guide AFFDL-TR-78-151, and the Parachute Recovery Systems Design Manual by Theo Knacke for the US military. Both are online... somewhere, and have been mentioned on dz. Attached is a pdf I made of the Altitude effect section of the more recent Knacke manual. It isn't ideal for our purposes but gives some idea of altitude issues. The rate of increase of opening force with altitude does depend on the design of the parachute, and whether the load is light (like a person) or heavy (like a bomb) relative to the size of the parachute. The research shown only applies to unreefed round canopies. I would imagine that the reefing of ram air parachutes would decrease the sensitivity to altitude, but would not change the basic principles (like higher true speed and energy when up high) or that higher altitude openings get harder. That's an awesome reference, thank you! Now, if you pay attention to figures 5-59 and 5-60, it looks like the opening force indeed does increase with the altitude, but no linearly. For instance, in figure 5-59, 28-FT, nylon: At 7000 feet the opening force is around 1600 pounds. At 40000 feet (~5.71x 7000 feet), the opening force is somewhere around 5200 pounds (~3.25x). The 28-FT silk chute opening force is somewhere around 4.1x. I was just curious, now my curiosity has been satisfied, thank you! Quote Share this post Link to post Share on other sites
Di0 2 #12 June 27, 2014 Jees, es super-hi, you never pull above fi thousan feet. He could have die that day.I'm standing on the edge With a vision in my head My body screams release me My dreams they must be fed... You're in flight. Quote Share this post Link to post Share on other sites
cs_troyk 0 #13 June 27, 2014 Di0Jees, es super-hi, you never pull above fi thousan feet. He could have die that day. You win the internets today, my friend. Legit LOL. Quote Share this post Link to post Share on other sites
chuteless 1 #14 June 27, 2014 You are totally wrong. The increase in speed would blow the canopy apart. It is a good thing Felix didnt pull high. At past the speed of sound, he wouldn't have had a chute ( except for the reserve. I have travelled at high speed from 7 miles up, and I would hate to have to use either chute at anything over 20,000 ft. That is when you get ground rush, and a chute wouldnt open in one piece at that high. I have been to 43,000 in a chamber, but they didnt have any way to simulate an opening shock at that altitude, but the did simulate the freefall , rapid descent.When jumping at Quito Ecuador, we went to 17,500 feet to get a 30 second delay, so with the land at 9500 ASL, we would be pulling at another 2000 ft above that. No noticeable difference than jumping in Ontario. Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #15 June 30, 2014 motorheaddown***Read from THIS post, down: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4640744#4640744 Interesting... Looks like I'm wrong. Thanks, -scott QuoteI just sat through a high altitude training class sponsored by the military (I'm a civilian) This should have given you your first clue. They generally don't just make up training information. Quote Share this post Link to post Share on other sites
excaza 1 #16 June 30, 2014 CSpenceFLYThis should have given you your first clue. They generally don't just make up training information. No sense discouraging inquiry so casually. There is nothing wrong with wanting to understand what you're being taught. Though this isn't one of them, there are more than a few examples of modern scientific dogma that have gone quite far with little to no backing. Military training is not exempt. Quote Share this post Link to post Share on other sites
