lyosha 50 #1 Posted April 9, 2024 Just curious what about kevlar made it a poor choice and why the world went to dacron/spectra/vectran/hma. Quote Share this post Link to post Share on other sites
mark 107 #2 April 9, 2024 The line sequence was: sheath-and-core dacron kevlar spectra vectran/hma Kevlar has poor abrasion resistance. It is also skinnier than dacron, so less friction in slider grommets and harder openings. Also, kevlar doesn't stretch much, so less shock absorption than dacron. 2 Quote Share this post Link to post Share on other sites
pchapman 279 #3 April 9, 2024 (edited) To humbly expand a bit on Mark's statement: The wear & abrasion (to itself) issue was the big problem that people talked about. It was all a bit before my time, but Kevlar didn't work out on main canopies, while it was used on a few early ram air reserves, where the frequency of packing was less. (As the OP may know, but I'm just giving a bit of history.) It also was used for a while for high strength reinforcements -- Like reinforcement circumferential bands on lightweight National Phantom round reserves, or being used as reinforcement tapes in ram-air reserves, or being used as the reserve closing loop for the then-popular Racer rigs. I guess it was the first 'extra strength' material out there in use! Kevlar is "an HMA", a high modulus aramid, but must be formulated & woven in a different manner than our current HMA lines which last better. (Although clearly they have their wear issues too, if made really skinny...) So Kevlar had a real wear problem. While for the other things Mark mentions, it was more a case of "being ahead of its time" rather than being inherently deficient -- We didn't all have stainless grommets to resist abrasion, and canopy designs & packing techniques weren't ready either. Just like the early days of Microline / Spectra, where there were more problems with instant openings, broken risers, too small sliders, etc. Thus part of the whole problem was the changes in rigging technique & design needed, for the new material. Here's an example from a 1980 [Edit: corrected. Not '85] CSPA rigger's bulletin, where they quote GQ Security (which produced the Unit ram-air canopy, some of which had Kevlar lines) on some of the pitfalls for riggers to watch for: Quote We have received numerous telephone calls and written inquiries concerning field refit programs of canopies with Kevlar suspension lines. Kevlar, which is an aramid fibre such as Nomex, was primarily used up to this point for reinforcing cords in automobile tires. Several things should be understood about Kevlar. Kevlar has zero (0) elongation characteristics. Kevlar should NEVER be used for a round canopy suspension line set. Kevlar is also very strong and has a much higher breaking strength than a similar denier nylon braided or twisted cord. Kevlar has very, very little resistance to abrasion. We feel that local experimentation should be discouraged. Ram Air canopy owners interested in having Kevlar line conversion should be urged to contact the manufacturer of their canopy for specific information. Some of the information that they must know is: 1. Kevlar cannot be successfully finger trapped. 2. Zigzag stitching of Kevlar is particularly tricky. 3. Steering lines may be made of Kevlar down to the lower control line portion. Lower control lines should never be made of Kevlar because of the constant running through rings. Also, the constant daisy‑chaining of brakes would cause Kevlar used at that point to wear out very rapidly and possibly break. 4. People owning canopies equipped with Kevlar lines must be constantly vigilant to inspect the entire metal surface of every grommet on their slider after every jump to insure that it is not nicked, pitted or roughed‑up in any way. Grommets found to be damaged in any way should immediately be smoothed off with a very fine grained emery paper. The same procedure would apply to Rapide links. Local riggers must be discouraged from purchasing bulk Kevlar lines and attempting to design and install line sets on Ram Air Canopies using the normal techniques applied to coreless, braided lines made of nylon or dacron. We are fully aware that every holder of a Master Rigger's rating feels that he is qualified to make this type of alteration and the technical judgements required. We are stating, categorically, that we feel that this is not the case and that if this practice is allowed that it may have serious or even fatal consequences in some cases. We are enlisting the aid of the C.S.P.A., U.S.P.A., the Safety and Training Committee, the P.E.I.A., and all Conference Directors in assisting us in this effort. G.Q. Security Parachutes, Inc. will not sell Kevlar line sets or bulk Kevlar to be used on any canopy but a Unit and only in cases where we know the qualifications of the individuals making the request. We hope that other manufacturers of Ram Air canopies will take the same measures. Edited April 9, 2024 by pchapman Quote Share this post Link to post Share on other sites
lyosha 50 #4 April 9, 2024 (edited) For context, I'm asking because these guys use kevlar for plane attachment straps (kind of like the "risers" of the system) https://brsaerospace.com/ And when I asked them "why kevlar?" they mentioned it was more abrasion resistant... which I found odd. Edited April 9, 2024 by lyosha Quote Share this post Link to post Share on other sites
pchapman 279 #5 April 9, 2024 Yeah, I don't know all the in's and out's of Kevlar abrasion resistance, in particular how old Kevlar lines got a poor reputation for degrading so quickly. Was it because of Kevlar on Kevlar between lines? Or a lot of flexing with say coarser weave lines? Or the formulation of Kevlar at the time? Certainly Kevlar doesn't tend to get for example the same 'line burns' that spectra or nylon might, being more resistant to heat and that kind of abrasion. (E.g., in Kevlar reinforcement on some kill line bridles.) Kevlar is better in that way. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,360 #6 April 9, 2024 3 hours ago, lyosha said: For context, I'm asking because these guys use kevlar for plane attachment straps (kind of like the "risers" of the system) https://brsaerospace.com/ And when I asked them "why kevlar?" they mentioned it was more abrasion resistant... which I found odd. Hi Iyosha, Re: it was more abrasion resistant Every day, all over the world, engineers are working on development/improvement of 'whatever.' We do not live in a stagnant world. Jerry Baumchen Mech Engr, Ret'd Quote Share this post Link to post Share on other sites
fcajump 164 #7 April 18, 2024 On 4/9/2024 at 11:45 AM, pchapman said: Yeah, I don't know all the in's and out's of Kevlar abrasion resistance, in particular how old Kevlar lines got a poor reputation for degrading so quickly. Was it because of Kevlar on Kevlar between lines? Or a lot of flexing with say coarser weave lines? Or the formulation of Kevlar at the time? Certainly Kevlar doesn't tend to get for example the same 'line burns' that spectra or nylon might, being more resistant to heat and that kind of abrasion. (E.g., in Kevlar reinforcement on some kill line bridles.) Kevlar is better in that way. While I've packed a couple reserves that had Kevlar lines, I don't know the ins/outs of the issue well... What I was told at the time is that it was a two-stage issue: - Kevlar lines would abrade the metal components (brass slider grommets / steering guide rings) until there was a sharp area where it metal component has worn - that sharp area would then cut the Kevlar fibers. Justification for use on the reserves was that they were strong/low-bulk and acceptable for low-use items where the abrasion issue would take much longer to present itself. JW Quote Share this post Link to post Share on other sites
councilman24 37 #8 June 22, 2024 I'll add to an old topic. One of the reputations was being brittle and susceptible to what I guess I'll call micro abrasion. In dusty, sandy areas it seemed the grit getting into the lines abraded the fibers and lines were breaking that looked fine. Remember Kevlar tape is used to line kill line bridles, was an initial attempt to reduce friction on cutaway cables both riser cable end keepers and soft housings. I have a like new Raven (I think) reserve with kevar lines. Quote Share this post Link to post Share on other sites
riggerrob 643 #9 June 24, 2024 Just don’t plan on doing more than 70 jumps on a set of Kevlar suspension lines. After 60 hard openings Kevlar lines start to snap in an unpredictable manner. Back during the 1990s, after a Strong Tandem reserve had 20 or 25 deployments, we re-lined them with Dacron and put another 600 to 900 jumps on them as mains. Nobody expected a main to last much more than 1,000 jumps in the gritty Southern California desert. Quote Share this post Link to post Share on other sites
