Piro 0 #1 August 29, 2013 Hello, I am planning on buying a weight belt to help me a bit with my fall rate (for 4-way formations and when jumping with other people who fall a lot faster), and I am planning on purchasing one with roughly 8-10lbs. I was asked by the manufacturer if I wanted the weights in bags of 1lbs or 2lbs (and that they usually do 2lbs). I was thinking of asking for 1lbs bags because they seem to be "universal" and easier to find if I need to add more. Also might be better if I would like to remove 1lbs instead of 2 in 1 go. I am mostly looking for some advice/ opinions on the subject. Thanks in advance for the replies and help. Quote Share this post Link to post Share on other sites
Cmp0806 0 #2 August 29, 2013 Hi there! I have a belt with the weights in 2lb increments. I like it a lot and recommend the 2 lbs units. I don't really see a need to have them in 1 lb increments. 1 lb (hell, even 2 lbs) doesn't make that big of a difference. Normally if I'm going to go to the trouble of adding/removing weight units, I do at least 4 lbs at a time. (Obviously don't wear too much weight or make drastic changes until you're used to flying with a weight belt.) When you're on a 10 min. call and need to add 6 lbs, do you want to sit there fiddling with 6 thingamajigs or 3? And when you have some of the weight out do you want to have to keep up with a bunch of little weight units or half that many? Also, I did get a good quality belt, but did not pay someone else to make the weight units. I got a bunch of BB's, weighed out 2 lbs, and put them in doubled-up Ziplock bags. Cost about $20. Quote Share this post Link to post Share on other sites
drudchen 0 #3 August 29, 2013 +1 for 2lbs pockets. It's just easier. If they fit in the weight belt But then again, I fly with 20lbs belt with my 4way team, so if you fly with less maybe it's less annoying to adjust Quote Share this post Link to post Share on other sites
Piro 0 #4 August 30, 2013 Thanks for the information guys I think I will end up asking for the 2lbs option, after reading the comments it makes sense Quote Share this post Link to post Share on other sites
