1 1
SCS422
proper reserve deployment
I'm thinking about getting back into it but it's been YEARS since i jumped last, i have 7 reserve deployments but it was easier then, crap above, cutaway, done.  I have pretty much decided on my rig, Infinity w/Optimum, AAD Maards, with all this stuff in my reserve i am visualizing the proper procedures,it's still crap above get rid of it but i have never had a total and with all that stuff attached to my reserve i am wondering what goes on with a total????
Hi 442,
Watch here:  RAX Demo (youtube.com)
Or, the videos on the VSE website.
Jerry Baumchen
(edited)
6 minutes ago, SCS422 said:
Nice, that shows the deployment but i'd like to know exactly how it does that on a total.  I didn't know you lived in beaverton, I am in Springfield
Hi neighbor,
Look here:  Velocity Skydiving Equipment | Infinity Rigs and Skydiving Gear (velocityrigs.com)
Jerry Baumchen
PS)  VSE is now located in Sisters, OR; you could easily just take a day & visit Kelly.  Call ahead to make sure he will be there & that they will be open.   A couple of hours there & you should learn a lot.
Edited by JerryBaumchen
1 hour ago, JerryBaumchen said:
Hi neighbor,
Jerry Baumchen
I am going there with  my canopies to get fitted for the containers,  I am going to check ALL things out when i go
  • Like 1
3 minutes ago, Veis said:
Yes, but this trigger steals some piece of energy of the PC, if deployment were without cutaway. We recently had a fatal case with suspected involvement of MARD..
The simpler the better, IMHO.
Where was this at and what are the arrived at particulars?
(edited)
22 minutes ago, Veis said:
Waiting for the report..
I watched this but could not determine how the maards system was involved.  ie. no attempt at a cutaway that i could determine and if he had an AAD most likely was not falling fast enough for it to deploy the reserve.  Disclaimer.....this is only my "not well informed opinion"
Edited by SCS422
  • Like 1
(edited)
53 minutes ago, SCS422 said:
I watched this but could not determine how the maards system was involved.  ie no attempt at a cutaway that i could determine and if he had an AAD most likely was not falling fast enough for it to deploy the reserve.  Disclaimer.....this is only my "not well informed opinion"
The speed is too low for AAD, but sufficient for normal PC operation. For comparison, my cutaway in research tests with similar conditions (a small ellipse, a carousel, entering a reserve at the time of unlocking 3 rings).Without any MARDs, RSL etc.
https://youtu.be/wQEj7FxSIcU
Edited by Veis
His biggest problem was wasting waaaaay too much time with his malfunctioning main.
  • Like 1
pull the handle
have faith in your rigger and container manufacturer that the flaps will open and the pilot chute will launch, extracting the freebag.
(edited)
2 hours ago, kleggo said:
pull the handle
I wanted  to know (I went to the Velocity site to find out) the exact sequence of events that take place when there is a MARD and AAD in place.
Edited by SCS422
  • Like 1
(edited)
 If you have a total and do not pull your reserve handle your AAD will fire and your MARD will release it's hold on the reserve bridle allowing the reserve P/C to deploy the freebag and canopy in the usual way. If you pull the handle on time the same thing will happen. The MARD releasing is accomplished in different ways depending on the manufacturer so the exact sequence will depend on the design. The specific information for each is available on their websites. MARDs add considerable complexity to reserve deployment systems and require careful attention from riggers. Manufacturers go to great lengths to make them as foolproof as possible. It is regrettable that once the container is closed there is no way short of opening it to check for correct rigging.
Edited by gowlerk
Yes, the Devil is in the details with that setup and requires careful attention that's why I wanted to obtain as much info as possible on the operation of that system.
The reason I am going to great lengths is that I have not jumped in years (read my first post) and wish to start again, I only have a few jumps on squares and I wish to be entirely cognizant of the new way reserves are setup, the way totals are addressed now withs the RSL and MARD is very different than when I stopped jumping.
Hi Ken,
Not totally true.  The VSE MARD can be seen by the window in the upper closing reserve flap.
Jerry Baumchen
  • Like 2
1 1
