Beerlight
Highest Hot Air Balloon Jump
Anyone have the video from the 40K hot air balloon jump that took place at Edwards AFB, CA about 6 or 7 years ago? It was on TV, not sure what the show's name was. The balloon was circled by an F-16 filming some of the footage, as well as great on-board footage. One of the guys that jumped, had his oxygen turned off accidentally, and went unconcious from hypoxia. I'd like to use that vid in one of my classes.
Thanks,
Buck
Bill,
I see your point. But, supposedly they used special burners that would ignite in the rarefied air. If I remember correctly, they had to re-ignite the burners on several occasions due to oxygen starvation problems. I think their final altitude was something like 43K. I'm checking with some of my Air Force (AF) brethren that might have worked on the project. It was co-sponsored by the AF.
Is this the guy you're asking about? Joe Kittinger? He holds the record for the highest altitude skydive. 102,000 FEET!!! He said when he left the balloon it didn't even feel like he was falling. Because of the lack of air resistance. Thought he had gone above the gravitational pull. First man to break the speed of sound without an aircraft!!!
http://www.stratoquest.com/default.cfm?page=5
http://www.pbs.org/wgbh/nova/escape/skydive.html
http://bodypilot.bounceme.net
he would have broken the Speed of sound if he had not used a drogue chute to stabilize himself in the rarified atmosphere.
He did hit over 500 MPH, the Speed of Sound approx 680 MPH
Good jump nevertheless. Imagine that one in your log book.!!!!
What was the speed of sound at his exit altitude? Doesn't the speed of sound decrease as the medium becomes more compressible?
Pull.
I just checked out the Speed of sound on the internet.
I guessed that the temperature at 102000 ft would be -60 C, and I clicked on the site and all the other data based on that Celcius temperature potpped in
It reads:
-60 C = -76F
which gives 294.799 Meters per second
967.1916 Feet per second
660.352 Miles per hour
That is the speed of sound with tghe Temperature at 102000 feet "GUESSED" at -60 celcius.
I al;so checked out the Speed of sound with a proposed temperature of
+ 20 Celcius which equals
68 F......which gives the speed of sound as
343,599 Meters per second
1127.296 feet per second
769.664 Miles per hour
This indicates that the Speed of sound increases as the temperature increases, and I would think this would take into consideration that the increase in Temp would also mean heavier atmosphere.
Bill Cole D-41
I know Joe opened "high", but imagine if someone was already opened and Joe passed close to him still in freefall. Wouldnt that guy do a double take? LOL
I'm just trying to figure out how you'd spot that high up...
Not like you'd see the dropzone...right? ;)
That would be an amazing jump.
Elfanie
My Skydiving Page
Fly Safe - Soft Landings
Just like any other jump, 5 right, 5 right, 5 right, 10 left and cut.
Sparky
Guess you'd call this a hijacked thread!!!!:ph34r:
But really, it was a hot air balloon jump, 40,000 feet or a lil higher, Edwards AFB, sometime in the early 90's.
TOMMY LAND if your out there I know you set up the oxygen console for the jump I'm talking about!!!
TOMMY..........HELP!!!! or any of the phyz techs that were at Edwards then.
wroooooooong. the speed of sound DECREASES as the altitude increases. Think about it. Sound travels much much faster in water. Why? because water is very dense, and this is also why sound travels better on cold, humid days. Therefore you could think that sound travels better at high altitudes since its so cold up there, but the air pressure at that altitude is much less, and the density as a result is very miniscule. i dont have the willpower to go back to my books and figure out what the speed of sound was at that high altitude, but it's less then 680 mph. 680 mph is at ground level. Sorry i'm pretty brief in describing it but i'm extremely worn out and was just dropping in to make a correction. :)
In establishing the figures I posted, I guessed at the temperature. I believe the temperature stays about the same all the way to infinity, once you reach a certain altitude, ( I think somewhere around 50,000 feet.)
I also stated that the 680 was MSL, but if you lookat the figures for -60Celcius, It seems about right or close to it.
Bill Cole D-41
speed of sound at sea level: 761 mph
speed of sound at approx 40k ft: 660 mph
looking at a few websites, I finally found one that has a non-bugged speed of sound calculator.
http://www.aerospaceweb.org/question/atmosphere/q0102c.shtml
but it appears as though the speed of sound at 100k ft, where that other guy jumped from, is 675 mph., so it doesn't vary uniformly with altitude.
MB 3528, RB 1182
I have that video and was part of the team. Jeff Sobolik, main jumper (his prodject) JayJay Johnson cameraman jumper from the Wings of Blue AirForce skydive team, Scott Cox was the onboard oxygen monitor and Major Ron Rosepink piloted the balloon. Jeff was 200 feet off the deck when he unstowed the brakes !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:S[email]me jwillwon3@yahoo.com
