MooChooser 0 #1 January 20, 2010 Does anyone know why the otter doesnt have wing tanks? Quote Share this post Link to post Share on other sites
JohnRich 4 #2 January 20, 2010 Because it has enough room in the belly? Quote Share this post Link to post Share on other sites
diablopilot 2 #3 January 20, 2010 Some do, if they've got the long range kit.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
pchapman 279 #4 January 20, 2010 I don't know for sure but my vague suspicions are: High wing plus bush plane origins; harder to hand pump fuel into the wings. (Not that ladders weren't needed anyway, if only to deice the wings & tail ...) The single Otter and Beaver had fuselage tanks too (didn't they?) so there's precedent from the company's earlier products. Not sure if a newly certified plane under FAR 23 or whatever would normally be allowed fuselage tanks any more -- there may be more emphasis on getting the fuel away from the cabin, no matter what disadvantages may occur too. (The Twin Otter was certified under the old CAR 3 preceding FAR 23.) Quote Share this post Link to post Share on other sites
vpjr 18 #5 January 20, 2010 If you are in the Bush and trying to fuel a high wing plane out of 55 gal drums you would have to work harder hand pumping the fuel to that height. I used to know the math. The belly tanks limit how high you have to raise the fuel. Less work. Boost pumps in the tanks do the rest of the work to the engines. Quote Share this post Link to post Share on other sites
totter 2 #6 January 20, 2010 QuoteHigh wing plus bush plane origins; harder to hand pump fuel into the wings The Twin Otter wing tanks are pressure refuelled. There are no Fuel Fillers on the wings. QuoteThe single Otter and Beaver had fuselage tanks too Yes. The Beaver can also be equipped with wing tip tanks that have to be filled on the wing and then are gravity drained to the forward fuselage tank. The Single Otter never was equipped with wing tanks. QuoteNot sure if a newly certified plane under FAR 23 or whatever would normally be allowed fuselage tanks any more The DHC-6-400 still maintains the fuselage tanks and this aircraft is certified under the current provisions of Part 23. Quote Share this post Link to post Share on other sites
diverdriver 5 #7 January 21, 2010 QuoteQuoteHigh wing plus bush plane origins; harder to hand pump fuel into the wings The Twin Otter wing tanks are pressure refuelled. There are no Fuel Fillers on the wings. There might be some twin otters with single point refueling (which would be pressure refuelled) but most are definitely not pressure refueled. And there are long range tanks that are fueled over the top of the wing.Chris Schindler www.diverdriver.com ATP/D-19012 FB #4125 Quote Share this post Link to post Share on other sites
riggerrob 643 #8 January 21, 2010 " ... (Not that ladders weren't needed ..." ......................................................................... Ladders are amusing on ski-planes and are an hilarious on float planes! Quote Share this post Link to post Share on other sites
totter 2 #9 January 21, 2010 QuoteThere might be some twin otters with single point refueling (which would be pressure refuelled) but most are definitely not pressure refueled. And there are long range tanks that are fueled over the top of the wing. Chris, You need to refresh yourself on the Wing Tank System of the Twin Otter by reading Supplement 8 to the AFM. There are two ways to fuel the wings. The first is Over The Wing using the filler neck on each tank. The second way is to "Pressure Fuel" the wing tanks using the Boost Pumps in each collector cell. This is not Single Point re-fuelling. You actually fill either the Forward or Aft fuselage tank. Fwd supplies the RH Wing, Aft supplies the LH Wing. With boost pumps on you select Re-fuel on the appropriate 3-position wing tank switch. This OPENS the re-fuelling valve, at the wing tank, allowing fuel to flow INTO the wing tank from the collector cell. You watch the qnty gauge to know when its full. No need to use a ladder to fuel the wing. I missed stating "No Fuel Fillers on the wing" in my original post. Should have read "No need to use the fuel fillers on the wing" Quote Share this post Link to post Share on other sites
diablopilot 2 #10 January 21, 2010 Not in disagreement with what you've stated, but there are some Otters out there equipped with Single Point.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
totter 2 #11 January 21, 2010 Quotebut there are some Otters out there equipped with Single Point. If there are then it probably would be a military conversion. I've never heard of any. deHavilland never offered Single Point re-fuelling, (not even as an S.O.O.), on any of the variants. This includes the -100, 200, 210, 300, 310 & 320. Viking is not offering it, even as an option, on the -400. There are no STCs either. Quote Share this post Link to post Share on other sites
diablopilot 2 #12 January 21, 2010 Pretty sure there is one sitting down at Perris, N708PV to the best of my recollection had a SPF system installed, and I seem to remember a conversation about it having had it for it's use in Hawaii as a commuter.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
diverdriver 5 #13 January 22, 2010 QuoteQuoteThere might be some twin otters with single point refueling (which would be pressure refuelled) but most are definitely not pressure refueled. And there are long range tanks that are fueled over the top of the wing. Chris, You need to refresh yourself on the Wing Tank System of the Twin Otter by reading Supplement 8 to the AFM. ........ I missed stating "No Fuel Fillers on the wing" in my original post. Should have read "No need to use the fuel fillers on the wing" Ah. That's where I got misremembered.Chris Schindler www.diverdriver.com ATP/D-19012 FB #4125 Quote Share this post Link to post Share on other sites
totter 2 #14 January 22, 2010 QuoteAh. That's where I got misremembered. Sorry about that. Brain moving faster than fingers. Quote Share this post Link to post Share on other sites
MooChooser 0 #15 January 22, 2010 Thanks for the replies Quote Share this post Link to post Share on other sites
