BIGUN 1,399
QuoteSo do you believe that I should not have cut away? The instructors I talked to thought I made the correct choice.
My apologies if you took my response as dissention of your actions. You acted and you lived. My response was intended exactly as written - to discuss alternates of choice with your Instructors about being at =/< 1000' and should you find yourself in that situation again (hopefully not). For you, what is that "some point?" And, what would you do? The round table discussion is a great tool in our learning arsenal for everyone at the DZ to learn from the actions of others, alternates of choice and mitigating risks.
Edit to Add: I re-read your first post because I didn't remember your saying you had discussed it with your Instructors which was not in there - hence, the suggestion to talk with them.
DSE 5
I'd been on two previous loads, and one post-cutaway load, and previous loads, there was turbulence around 2K. I wonder if turbulence coincided with turn, resulting in the spin-up, or if there was actually a spin in the air. We do see dust devils, but not often over the green area.
Although I didn't see Chigbee's actual cutaway (I was watching another cutaway, ironic there were two on the same load, the other pilot an instructor with thousands of jumps), I did see where Chigbee had cutaway due to his floating main within a second after he'd chopped.
Was it the right call? The altitude he was at suggests not. On the other hand, he also might not have been able to kick out quickly enough. In this particular situation, he acted quickly and not only survived, but walked away from it.
Everyone, from DZO down, felt he'd done the right thing given his choices. I don't know if I'd have done the same, I wasn't the one in the harness.
Proud of you, Chigbee! And congrats for getting right back up immediately, but you shoulda stayed long enough to pack the rig you borrowed from me.
quade 4
Come to Perris!
It's the ones that have formed over the clean runway or the grass that you -can't- see that are especially dangerous.
DSE 5
QuoteQuote
Come to Perris!
Been there, done that. No thanks, I like ours where you can see the dirt in them.
AFFI 0
Enlighten me.
You mention releasing toggles at 1,000, do you mean unstowing?
Rule fo thumb - do not preform radical manuevers below an altitude you are not willing to cutaway from.
Skydiving Priorities: 1) Open Canopy. 2) Land Safely. 3) Don’t hurt anyone. 4) Repeat…
swoopgaz 0
JohnMitchell 16
Was your airspeed low when you initiated a turn? From slow flight to sudden turns can initiate line twists more easily.
I don't think 1000 feet is too low to chop, especially in that situation. I wouldn't be happy about it, but I've seen it done successfully a number of times. If you chop that low, make sure you pull your reserve immediately and arch. Don't screw around trying to get stable.
chigbee 0
I know Spot, I feel bad about it too. I owe you big time. I will show up next time with offerings.
chigbee 0
No I mean releasing them from my hands when I grabbed my risers. They were unstowed much higher.
As far as my HD @ 1800' what I mean by that is that is my decision altitude of when I quit trying to fix a problem with my main.
pfloyd 0
staysafe 0
VTflyer 0
Did you ever find out if there was an issue with your main?
QuoteSo I had my first cutaway this weekend and I can’t figure out what may have caused it. Here is the rundown, second jump of the day, uneventful freefall, clear and pull @ 3500’, in the saddle with a fully functioning canopy by 2800’. I fly the canopy with no problems down to 1400’ at which time I initiate a turn which causes my canopy to go into a violent turn resulting in line twists. In the span of probably less than a second my lines have made 1.5 complete revolutions, I release my toggles which does stop the spinning but at this point I check my altimeter and realize that I am just about at 1000’ and make the decision to chop. I was sitting in a big beautiful canopy @ 600’.
I think I made the right decision to chop, I absolutely did not want to land a canopy with the line twists, and though I may have been able to kick out of them who knows.
My toggle turn was not a hard turn, I did not bury my toggle nor was it excessively fast. The only conclusion we could think of was that I was passing through 2 layers of air and somehow it just caught something weird. It was a sunny day about 75 degrees with light winds, not very turbulent at all.
I still owe beer because i am in Utah and it was the lords day so no alcohol sales, but I am good for it
Did you conduct a canopy controllability check (I like to call it Triple C's) after opening? The first thing that came to my mind was that you had a tension knot and when you buried a brake line the knot wouldn’t allow the line to retract, creating your spin and line twists. Therefore attempting to kick out of the twist would of rendered you useless as you had a brake line stuck. I've seen this before and it resulted in a chop. Cheer Mate!
Quotei was taught: below 1000ft go str8 to reserve and dont cut away first. (as much fabric as possible theory)
That sounds crazy.........................
Is this something they teach everywhere these days?
You could do half of a style set from 1,000 feet
AFFI 0
QuoteTriple C's
QuoteQuoteTriple C's
Canopy Controllability Check
(Look left, turn left 90*, Look right, turn right 90*, determine stall point) If you need to input more than 50% opposite toggle to counter a turn or the canopy stalls prior to 50% brakes then the canopy is considered uncontrollable and cut-away procedures should be initiated.
Cheers!
Andy9o8 2
QuoteThis is a jump you walked away from, so you must have done something right!
Not really directed to either you or the OP, but I think this is an over-used expression, especially when spoken to, by or in the presence of novices. It's fine to give a some props to a novice who's handled an EP and is a little bug-eyed from having looked The Reaper in the eye. Experienced jumpers hopefully understand that being lucky enough to have a good result "this time" does not necessarily define a sound practice. It may or may not be that, viewed objectively, what the OP did was a good course of action; I'll let others (like the instructors at his DZ) decide that. But just as sometimes you do can everything right and it still bites you, sometimes you manage to make it out OK despite your errors. Actions that are "not the best idea" are still that, despite the outcome, and should still be identified as such and corrected, so that they're not repeated, either by the same jumper or the other impressionable novices around the bonfire.
I'm guessing thats why you felt 1000 as the "hard deck" ?
IMO the forum isnt really the place to second guess yourself in this case and with your # of jumps. Although some of the guys here have an awefull lot of experience and they mean well. I would just stick with your instructors comments and leave the finer points people bring up here for later, when you have a better understanding of them yourself. At least thats what I would do. Better spend your energy on the next jump, using what you have learned, instead of dwelling on one that didnt go as planned.
Just my 2 ct. @ 80 jumps ;P
