billvon 3,068 #26 November 23, 2005 >It is a very viable option. Look at the line-over mod for BASE. Toss >the steering lines and fly the rear risers. Works fine. Warning - BASE canopies are NOT like skydiving canopies! I watched two separate canopies land people very hard in the water during Bridge Day 1997, because the jumpers put a line-release mod on their canopies then inadvertantly let go of their toggles (no malfunction.) The tails of their canopies folded up and dropped them pretty hard. Fortunately they both landed in the river. I don't know what kind they were, other than one was a large 7-cell and one was a smaller one. Quote Share this post Link to post Share on other sites
Hooknswoop 19 #27 November 23, 2005 Quote Warning - BASE canopies are NOT like skydiving canopies! I watched two separate canopies land people very hard in the water during Bridge Day 1997, because the jumpers put a line-release mod on their canopies then inadvertantly let go of their toggles (no malfunction.) The tails of their canopies folded up and dropped them pretty hard. Fortunately they both landed in the river. I don't know what kind they were, other than one was a large 7-cell and one was a smaller one. Thanks Bill, very true. Some canopies will react that way. Derek Quote Share this post Link to post Share on other sites
mjosparky 4 #28 November 23, 2005 Jim, There was only one person close enough to the problem to make an informed decision on what to do. I am not sure what I would do, I wasn’t there. Sounds to me like you kept yourself updated as to altitude and canopy condition and walked away. That puts you way ahead of some that were landing a canopy in perfect condition. Sparky Effective packing is all about the little detail.My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
Peej 0 #29 November 23, 2005 Quote Sounds like you did a good job dealing with a tough situation. Im not saying what you did was wrong, but I would have chopped. My decision to chop in the situation you were in comes from A) low jump numbers and B) an ingrained predetermined decision that if I can't fly it in the air without stress, I probably won't land it without breaking myself. You have a ton more experience than I do so maybe in the future my decision will mirror yours but at this point, Im buyin a rigger a bottle Seconded. At my experience level i'd have got rid of it. Advertisio Rodriguez / Sky Quote Share this post Link to post Share on other sites
kallend 2,106 #30 November 23, 2005 Quote Ah the old hook knife! Unfortunately in the chain of events, I removed it from my chest strap because I carried the rig on board the aircraft when I left Houston. Of course, I failed to put it back on when I got to Eloy starting the whole chain of events. You too with hook knife at the airport! It took me a month or so before I remembered to put mine back. Fortunately its absence did not initiate a malfunction in my case.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
TomAiello 26 #31 November 23, 2005 Quote Quote It is a very viable option. Look at the line-over mod for BASE. Toss the steering lines and fly the rear risers. Works fine. Warning - BASE canopies are NOT like skydiving canopies! I watched two separate canopies land people very hard in the water during Bridge Day 1997, because the jumpers put a line-release mod on their canopies then inadvertantly let go of their toggles (no malfunction.) The tails of their canopies folded up and dropped them pretty hard. Fortunately they both landed in the river. Even on a BASE canopy, the procedure I teach when ditching a toggle is to keep the other one in hand to minimize tail deflection when flaring with (both) rear risers. I have landed BASE canopies on rear risers with both toggles in hand, one toggle in hand and the other trailing, and no toggles. On those canopies (265+ square foot 7 cells) the difference between those three states was much less than I had expected. It was noticeable, but only just. I have no idea how this applies to skydiving canopies. Them little zippy high performance postage stamps scare me.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Quote Share this post Link to post Share on other sites
Praetorian 1 #32 November 23, 2005 Um ... you have me scared here, I thought I knew my main pretty well.. when my breaks are unstowed, full flight the slack in the lines means the tail of the chute is holding its shape with no tension on the break lines... would the main fly differently if the break lines were cut insted of with no tension? I'm not talking c or d lines here? Good Judgment comes from experience...a lot of experience comes from bad judgment. Quote Share this post Link to post Share on other sites
billvon 3,068 #33 November 23, 2005 >the slack in the lines means the tail of the chute is holding its >shape with no tension on the break lines... Well, there is never really 'no tension on the brake lines.' If they are bowed, it means the only tension is that supplied by the air, which is a few pounds pulling backwards (translates to downwards due to the way the lines are attached.) If the lines are 'freed' they are now pulling only backwards, not downwards. Some canopies do have trouble with this; their tails 'flip up.' This has the opposite effect as a flare. Quote Share this post Link to post Share on other sites
joebud321 0 #34 November 23, 2005 Quote Quote Ah the old hook knife! Unfortunately in the chain of events, I removed it from my chest strap because I carried the rig on board the aircraft when I left Houston. Of course, I failed to put it back on when I got to Eloy starting the whole chain of events. You too with hook knife at the airport! It took me a month or so before I remembered to put mine back. Fortunately its absence did not initiate a malfunction in my case. dont you guys check that someone has a hook knive on a a gear check????......we arnt aloud on a plain without one!.....and im very happy thats the case Quote Share this post Link to post Share on other sites
mattjw916 2 #35 November 23, 2005 Hook knives are not "required" by the USPA. I think most people would either drop it, poke themselves in the eye, or cut the wrong lines most of the time anyway. There's a H U G E thread about hook knife usage started by Ron I think somewhere around here. Personally, I probably wouldn't even think about cutting lines on my main, my reserve OTOH, I'd cut anything I thought I needed to in order to make it land safely. I carry a hook knife, never even thought about reaching for it though...NSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites
artistcalledian 0 #36 November 23, 2005 why are you supposed to carry a hook knife? what are they for?________________________________________ drive it like you stole it and f*ck the police Quote Share this post Link to post Share on other sites
JohnRich 4 #37 November 23, 2005 Quote What would I have done? I would not attempt to land a main canopy with a brake line knotted to the point of it being 16 inches shorter. I would first try to cut the brake line with my hook-knive and land on rear risers, and if I couldn't manage to get it cut, I'd cuttaway and pull my reserve. I have absolutely no doubt that I'm about to be flamed to Hades. Well, a lot of posts have been made since you made this, and no one has set you alight yet. I think there is a big difference between our personal opinions about what we would do, and what the person in question should have done. That's because we all jump different canopies, have different experience levels, have different landing zones, and so on. What's right for one person might be wrong for another. So none of us can really properly judge, because gemini was the only one that knew the exact circumstances; with his canopy, how it handled, its wingloading, his comfort with controllability, the size of his landing area, etc. All those factors go into the decision about what is "right". He handled it and walked away, so I call that right for him. Quote Share this post Link to post Share on other sites
AndyMan 7 #38 November 23, 2005 Quote He handled it and walked away, so I call that right for him. He asked for opinion. Was he right or wrong? To me, that means: "did I stack the odds in my favor and it worked", or "did I stack the odds against me, and I got lucky?" I sure as hell know that I've got plenty to learn in this sport, and I presume the same is true of gemini, and you, and everyone else. Since he asked, I answered. I think Gemini put the odds against him, when he could've put them in his favor. This isn't something I say lightly, but I know that it's the kind of answer that he's looking for - that's why he asked. It helps nobody for everyone to chime in "you walked away, you did the right thing". Giving that answer kills a perfectly good learning opportunity. We all can learn, especially from the mistakes we walk away from. I would prefer that people tell my why it isn't a mistake, than to tell me I'm not supposed to point it out. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
rehmwa 2 #39 November 23, 2005 Good job Jim. With a more radical canopy, I'd have likely cut away, but with a Sabre2 and a good control check no problem. Maybe I'd have held the good line in my teeth to let both hands work the toggle-tangle..... Actually, my very first cutaway was similar, except the fly straight point was much closer to stall, so I had to cut away. My only round jump on that reserve. ... Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants Quote Share this post Link to post Share on other sites
The111 1 #40 November 23, 2005 Quote It helps nobody for everyone to chime in "you walked away, you did the right thing". True. In my short time in the sport, I have already done a few stupid things that I got lucky and walked away from. Not commenting on this specific instance, but on the trend of the "walk away = ok" style responses.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
Andy9o8 2 #41 November 23, 2005 Quote why are you supposed to carry a hook knife? what are they for? http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1938647#1938647 Quote Share this post Link to post Share on other sites
Eule 0 #42 November 23, 2005 Quote Quote Unfortunately in the chain of events, I removed [the hook knife] from my chest strap because I carried the rig on board the aircraft when I left Houston. Of course, I failed to put it back on when I got to Eloy starting the whole chain of events. You too with hook knife at the airport! It took me a month or so before I remembered to put mine back. Sometimes parked airplanes will have a lot of covers or safety latches with big red "REMOVE BEFORE FLIGHT" ribbons hanging from them. Maybe this calls for an "INSTALL BEFORE FLIGHT" ribbon? Something like tying a pull-up cord (preferably brightly colored) around the hook knife pouch or the strap where it was when you take the knife out or off. Or shoving a folded-up dollar bill in the pouch with one end sticking out, or tie one of those freebie paper luggage tags around it, or whatever. Basically, something that's conspicuous and easy to do with available materials when you're wandering up to the check-in desk at the airport and suddenly remember you have to take the knife off. Hopefully, when you get where you are going, somebody (maybe even you) will notice the cord or the money or the tag and ask, "why is that there?" The above might be a bad idea for some reason I haven't thought of. It can also probably be argued that a gear check would prevent leaving the hook knife off. On the other hand, if someone else is giving you a gear check, a hook knife may not be as "essential" in their eyes - some people have them, some people don't. If I (as a n00b) was doing a gear check on a more experienced jumper, "you don't have a hook knife" would be a much lower priority than "where the hell is your reserve handle?" or "your left 3-ring is hooked up wrong". EulePLF does not stand for Please Land on Face. Quote Share this post Link to post Share on other sites
darkwing 5 #43 November 23, 2005 I've been thinking about this since you first posted. After much thought I think you did the wrong thing. I have seen several times cases where a seemingly static situation deteriorated. In your case it could have happened a couple of ways. As one person mentioned, the knot could have cleared at flare time. Also, being that deep means your canopy was MUCH more susceptible to a stall induced by turbulence from any source--wake turbulence from other canopies, thermals, gusts... I am very glad you came out OK, but I think you erred. I am willing to debate the philosophy that "if you walked away from it you did the right thing." -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
GravityGirl 0 #44 November 24, 2005 I was taught to only toss one brake line (the one with the line over ) and fly one brake line and one rear riser. I saw a jumper at bridge day toss both, and luckily he landed in water. It was U G L Y. ~~~~~~~~~~~~~~~~~ Peace and Blue Skies! Bonnie ==>Gravity Gear! Quote Share this post Link to post Share on other sites
Hooknswoop 19 #45 November 24, 2005 Quote I was taught to only toss one brake line (the one with the line over Wink) and fly one brake line and one rear riser. I saw a jumper at bridge day toss both, and luckily he landed in water. It was U G L Y. I think it depends on the canopy. I've tossed them on a Fury 220 and didn't have a problem, but like you said, it can cause a problem on other canopies. I wonder what the difference is? Derek Quote Share this post Link to post Share on other sites
GravityGirl 0 #46 November 24, 2005 Mabye trim? Maybe spacing between line attachments? I do know, that I DON'T want to be the test dummy on this one. ~~~~~~~~~~~~~~~~~ Peace and Blue Skies! Bonnie ==>Gravity Gear! Quote Share this post Link to post Share on other sites
bob.dino 1 #47 November 24, 2005 Give me a tertiary and I'll do it. Quote Share this post Link to post Share on other sites
gemini 0 #48 November 24, 2005 Quote the knot could have cleared at flare time There was no way the knot was going to clear where it was and how it was twisted around the toggle, but your point (and those similarly made by others) is valid and I worried about it prior to seeing how the knot was made. Blue skies, Jim Quote Share this post Link to post Share on other sites
skylord 1 #49 November 24, 2005 Quote Quote why are you supposed to carry a hook knife? what are they for? http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1938647#1938647 That was funny! (But is it true?) Bob FGF-1Bob Marks "-when you leave the airplane its all wrong til it goes right, its a whole different mindset, this is why you have system redundancy." Mattaman Quote Share this post Link to post Share on other sites
JohnRich 4 #50 November 24, 2005 Quote Quote He handled it and walked away, so I call that right for him. He asked for opinion. Was he right or wrong? To me, that means: "did I stack the odds in my favor and it worked", or "did I stack the odds against me, and I got lucky?" I sure as hell know that I've got plenty to learn in this sport, and I presume the same is true of gemini, and you, and everyone else. Since he asked, I answered. I think Gemini put the odds against him, when he could've put them in his favor. This isn't something I say lightly, but I know that it's the kind of answer that he's looking for - that's why he asked. It helps nobody for everyone to chime in "you walked away, you did the right thing". Giving that answer kills a perfectly good learning opportunity. We all can learn, especially from the mistakes we walk away from. I would prefer that people tell my why it isn't a mistake, than to tell me I'm not supposed to point it out. Down boy! Down! Chill out. I simply offered an opinion. I wasn't telling anyone else that they couldn't post different opinions, and I'm not trying to stifle the learning experience. Save the acrimony for the gun threads. I think gemini made his decisions wisely and was rewarded with a decent landing. I see nothing about that to be critical. And as an example of why we shouldn't second-guess the person who was there, is the post about how the knot could have come loose at flare time. Gemini had thought of that, and decided that the knot was secure enough that slippage wasn't going to happen. So we're here with second-hand speculation, while he was in the air with first-hand observation. He made the right decisions. Alternative decisions could have also been made, which were also correct. But as it is, he did great. So I see nothing to be critical about. Your mileage may vary. Quote Share this post Link to post Share on other sites
