As a former student at SDChicago (and now a regular jumper there) I think I can clarify.
Ditto
First jumps are tandems, with the student doing freefall maneuvers, practice handle touches, deploying at 5,500ft, and flying the canopy. Student is not just a passenger.
At the last tandem meeting I went to this was discussed: students do the practice touches, turns, etc on the first tandem. On the second tandem, the focus is on relaxing, arching, body awarness and pulling. Generally turns are not done on the second tandem so the student can gain confidence that they can relax while in freefall.
Canopy control, finding the airport, and landing procedures are included in both tandems. All students help with turns, flaring, etc. On second tandems, they are encouraged to steer the canopy to find the airport. This way a student doesn't feel so scared and isolated on their first AFP jump or under canopy.
From about 1993 - 1998 the first non-tandem jump was on a Sabre. Mine was a 190 (I weigh 150 in street clothes, about 175 - 180 out the door). After 3 jumps I went to a 170, and after 12 or 13 I went to a Sabre 150.
1999-2001 they used Safires
2002 - current they use Sabre IIs.
I started on a Safire 230, moved up to the Safire 260 when I had some landing issues, then moved down to the 230, 210 and eventually the 190 Safire on my last student jump and first rentals. I purchased a Sabre 230 as my first canopy since I had a hard time finding a rig that would fit a 190 at the time. I jumped a Stiletto 190 by jump 89 and owned one by jump 95, I've been under a Stiletto pretty much every jump since. Oh yea, all jumps were done via BOC on the training program.
While I was at Quincy 99 someone told me Roger would kill me because I was using BOC and a Safire during my student jumps. Funny thing is, Roger went to his DZ a few months later and helped convert his student program over to AFP, BOC and tapered canopies.
QuoteAll rigs are Javelins.
We now have one Student Mirage we are testing out.
QuoteThe point? I didn't learn anything I had to unlearn later.
Ditto. And I was glad to have that muscle memory on my first malfunction.
you can burn the land and boil the sea, but you can't take the sky from me....
I WILL fly again.....
billvon 3,173
>So at a 0.9 WL will a Sabre2 outperform a Stilletto???
Like asking "Will a 767 outperform a Gulfstream 5?" Depends on what "performance" means to you. The Stiletto will have a flatter glide and a slightly more powerful flare; the S2 will feel more stable and have better openings.
>Has anybody actually flown an eliptical at a 0.8 or 0.9 WL???
I jumped a Stiletto 190 at about .9 to 1 and it felt unstable to me at that loading. Not as bad as a Nova, but not very solid.
>Following that logic, could we put a student with a 200 pound exit
>weight on a Stiletto 280 rather than a Navigator 240.
A Stiletto at that weight would open poorly and not do well in turbulence.
skycat 0
I would call a lightly loaded Stiletto breathy but it had a nice flare, on the other hand I jumped a samauri at a fairly light loading and if was quite well behaved. From what I have found though on the light end of the scale for "Fully Ellipticals" (crossfire, stiletto, cobalt, samauri) you really don't want to load them less than 1.1 or 1.2:1.
Fly it like you stole it!
http://www.performancedesigns.com/faq.htm#5
What is the difference between a tapered, elliptical, or semi elliptical canopy?
These terms refer to the shape of the wing when viewed from above. Any canopy that is not rectangular can be called either semi-elliptical or tapered. The amount of taper affects the canopy handling and performance, though in combination with several other parameters.
While the term elliptical is often used to describe some canopies, no skydiving canopies are truly elliptical. The curve in a canopy is approximated by a series of straight-line segments, and they do not form a true ellipse. What we are really dealing with here is the relative degree of taper from one canopy to another. This involves not only how much taper there is, but where it is located. Some canopies are more tapered than others, regardless of whether they are called "elliptical" or "semi-elliptical.”
PD prefers to use the word "tapered” for several reasons. As soon as skydivers began using the word “elliptical,” many people created the idea that every "elliptical" canopy will have certain specific characteristics, some good and some bad. In reality, a non-rectangular canopy may not have any of those characteristics. We like the term “tapered” because it simply means “not rectangular,” while the term “elliptical” implies certain things about a canopy that may or may not be true.
Rather than the actual shape of a wing, most jumpers are really interested in performance characteristics: how does the canopy open, fly and land? These characteristics are influenced by taper, but not totally dictated by it. The degree of taper is part of a whole package. Airfoil, aspect ratio and trim angle are also very important. Wing loading, or body weight compared to canopy size, is actually the main factor that determines canopy speed. The degree of taper generally influences the responsiveness of a canopy, though other variables come into play. This is why it is not necessary for a jumper to know exactly how tapered or “elliptical” a particular canopy is. The proof is in the performance, and in the handling.
Therefore, it is best to read descriptions of the various canopies, and try demos of those that might suit your needs. Dealing with all the different terminology used can be confusing. Just remember that this terminology is often just one company's choice of packaging, rather than actually describing something different or new. Every company wants their products to be viewed as different from another. These types of word plays are one way to achieve that. In the end, the canopy’s performance in the air is what really matters.
