QuoteQuote
A) Check your canopy
B) Check for traffic (use rear risers to turn if necessary)
You might add - Turn toward your traffic pattern here![]()
C) collapse slider
D) pull down over toggles
E) Release brakes
I once spent way too much time focusing on getting my slider down after it had fouled with a partially unstowed brake line - all the while losing altitude & flying directly away from the DZ - and almost had to land out
Actually, I'd add, turn perpendicular to the line of flight.
billvon 3,065
I would suggest people NOT do this. You have no idea whether you are left or right of the line of flight after you open (usually) and therefore turning perpindicular to it might just put you back _on_ the line of flight, if you happen to turn towards it instead of away from it. Also, on anything bigger than a solo, it's more important to be facing away from the rest of your group for the first 5-10 seconds.
If anything, if you're a solo and you are worried about the next group colliding with you, it makes more sense to turn away from them (i.e. anti line of flight, towards the previous group that opened.)
Well, I can usually see where other people are opening. And I turn so that I'm not going toward those who got out in front of me or those who got out after. So, I turn 90 from them which I would think is perpendicular to the line of flight. Obviously if someone from my group is in that direction, I don't head right at them.
