rendezvous 0 #1 July 22, 2003 When I registered online the required reserve repack date mentioned in the confirmation was April 13th or after but the website says April 12 and after. Mine is April 12. Which one should I go by ? Quote Share this post Link to post Share on other sites
skymama 37 #2 July 22, 2003 The Reserve Repack Calculator says your reserve will be out of date on August 10th. So, I suppose as long as you're jumping before the 10th you should be good to go.She is Da Man, and you better not mess with Da Man, because she will lay some keepdown on you faster than, well, really fast. ~Billvon Quote Share this post Link to post Share on other sites
Jib 0 #3 July 22, 2003 QuoteSo, I suppose as long as you're jumping before the 10th you should be good to go. The website says: "Your gear must be 'in date' for the entire convention, even if you are not staying for the entire duration." So, if it's due the 10th, you're definitely SOL. www.freefall.com -------------------------------------------------- the depth of his depravity sickens me. -- Jerry Falwell, People v. Larry Flynt Quote Share this post Link to post Share on other sites
WFFC 1 #4 July 22, 2003 QuoteWhen I registered online the required reserve repack date mentioned in the confirmation was April 13th or after but the website says April 12 and after. Mine is April 12. Which one should I go by ? April 12th was the date provided by the local USPA regional director along with the explanation that, yes your rig is going out of date on the 10th, but it would be good until 11:59 P.M. August 10th. Quote Share this post Link to post Share on other sites
rendezvous 0 #5 July 22, 2003 So it means I'm good for the convention with a date of April 12th then, right ? Quote Share this post Link to post Share on other sites
WFFC 1 #6 July 22, 2003 According to them, right. That was the official date I was advised to use. Quote Share this post Link to post Share on other sites
