bovosh 0 #1 June 25, 2013 OPENED UP WITH LINE TWISTS AND A TOGGLE FIRE , I WAS HAPPY MY RESERVE OPENED UP ON HEADING [url]http://www.youtube.com/watch?v=e82cFnl_ER0 NOT SURE HOW TO MAKE IT SO YOU CAN CLICK ON THIS LINK BUT COPY AND PASTE INTO ADDRESS BAR Quote Share this post Link to post Share on other sites
YvonneWiggers 0 #2 June 25, 2013 bovosh OPENED UP WITH LINE TWISTS AND A TOGGLE FIRE , I WAS HAPPY MY RESERVE OPENED UP ON HEADING http://www.youtube.com/watch?v=e82cFnl_ER0 NOT SURE HOW TO MAKE IT SO YOU CAN CLICK ON THIS LINK BUT COPY AND PASTE INTO ADDRESS BAR there you go, clicky it is :) oh and this: [inline CapsLocksmall.jpg] Edited to add: Quote FIRST CUTAWAY MALFUNCTION SUNSET MADNESS!!!!!!! "So I jump out, look up, and think 'Oh SHIT!... It's PINK!!!'" - army guy after his first staticline jump Quote Share this post Link to post Share on other sites
devildog 0 #4 June 25, 2013 Holy raging capslock, batman!You stop breathing for a few minutes and everyone jumps to conclusions. Quote Share this post Link to post Share on other sites
IJskonijn 45 #5 June 25, 2013 too loud; didn't read Quote Share this post Link to post Share on other sites
shorehambeach 9 #6 June 25, 2013 Glad it turned out ok. I am trying to roughly work out how much loss of altitude the mal caused.... What height did you first pull at and what height did you have a reserve over head ? Thanks for posting Blue skies. Quote Share this post Link to post Share on other sites
bovosh 0 #7 June 25, 2013 deployed at 3500 according to my altimeter it said I was in the sattle by 2500, I chopped around 1500 and was in the sattle in the reserve around 1200-1300 Quote Share this post Link to post Share on other sites
Tetrahedron 13 #8 June 25, 2013 You think THAT'S scary? I suggest you don't EVER size down. Also, your friend needs a freefly friendly rig. Also........ BEER! Quote Share this post Link to post Share on other sites
DexterBase 1 #9 June 25, 2013 TetrahedronYou think THAT'S scary? I suggest you don't EVER size down. Also, your friend needs a freefly friendly rig. Also........ BEER! Aside from the comment about the open pin flap... one of the most unhelpful posts I've read here in this forum in quite some time. Quote Share this post Link to post Share on other sites
Tetrahedron 13 #10 June 25, 2013 Lighten up, spaz. It was a routine cutaway. He did everything the way he was supposed to. There's nothing more to learn from it. Quote Share this post Link to post Share on other sites
bovosh 0 #11 June 25, 2013 The one good thing to learn from this is to make sure your toggle keeper on the riser is not worn or loose. this will help prevent toggle fire Quote Share this post Link to post Share on other sites
Tetrahedron 13 #12 June 25, 2013 I'll add; make sure the cat's eye setting in the steering line is below the ring on the riser and when stowing the risers in the channels, make sure the toggles don't become loosened. That is, if you're packing for yourself. Sometime toggle fires just happen. You have to be prepared for that eventuality. Especially on a highly loaded canopy. Quote Share this post Link to post Share on other sites
mototryph1 0 #13 June 25, 2013 What DZ is that? Quote Share this post Link to post Share on other sites
phreeloader 0 #14 June 25, 2013 You were under reserve pretty quick after cut away, do you have a RSL? did you pull both handles? Quote Share this post Link to post Share on other sites
DcloudZ 0 #15 June 25, 2013 Tetrahedron Lighten up, spaz. It was a routine cutaway. He did everything the way he was supposed to. There's nothing more to learn from it. Don't jump to conclusions! I learned that you make silly assumptions and give bad advice*Edited to remove personal attack "Better to have a short life that is full of what you like doing than a long life spent in a miserable way." -Alan Watts Quote Share this post Link to post Share on other sites
bovosh 0 #16 June 25, 2013 yea , I had an rsl and I pulled my cutaway handle first then my reserve , funny thing is you don't think to hold on to them after haha Quote Share this post Link to post Share on other sites
Tetrahedron 13 #18 June 25, 2013 DcloudZ ***Lighten up, spaz. It was a routine cutaway. He did everything the way he was supposed to. There's nothing more to learn from it. Don't jump to conclusions! I learned that you make silly assumptions and give bad advice*Edited to remove personal attack And I learned that you're full of nothing but personal attacks. Quote Share this post Link to post Share on other sites
BIGUN 1,424 #19 June 26, 2013 >>>>>>Also, your friend needs a freefly friendly rig. The rig is freefly friendly. The friend is packing flap sequence challenged.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Tetrahedron 13 #20 June 26, 2013 Good to hear it. Thanks for the update. Quote Share this post Link to post Share on other sites
fcajump 164 #21 June 26, 2013 bovoshdeployed at 3500 according to my altimeter it said I was in the sattle by 2500, I chopped around 1500 and was in the sattle in the reserve around 1200-1300 Good try for correction and good decision to chop. Don't let the blowhards get ya, a mal is a mal and yours could have been deadly if you had not taken correct action in a timely manner. Been through a couple and each one is scary. It is true that a higher performance 'chute can make this look tame. (and frankly, so can a lightly loaded canopy) There are much scarier conditions. But, given a bad situation, you done good. JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
popsjumper 2 #22 June 26, 2013 Good job! The parts I liked best were: -you pulled the reserve handle anyway (good practice) -this vid is another testimonial to PULL THE DAMNED RESERVE EVEN IF YOU ARE SPINNING AT CUTAWAY! I feel better now. My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
Machupo 0 #23 June 26, 2013 bovoshSkydive The Ranch Thought I recognized the park across the river :) Glad everything worked out - and good job recognizing it was time to stop fighting and get out. At least it was beer-light thirty!γνῶθι σεαυτόν Quote Share this post Link to post Share on other sites
Bodhisattva420 0 #24 June 26, 2013 What type/size of canopy were you jumping? Quote Share this post Link to post Share on other sites
