Phlip 0
see talk back: "what about this extra minute"
Craig 0
QuoteI guess we were not really concern about this small variation because we are setting our Cypress to 450up or 420up (depend of people) and the landing area is ~300up or something, but there are some hills surrounding the area. So I think it's really hard to determine what settings we need. So my guess is that's why we are not really concerned about this little deviation.
But I totally agree it's safer to take is time and set the cypress at the packing area.
What altitude difference does your altimiters read between the landing area and the airport? There is the altitude difference, pretty darn close anyway. In my opinion you really should set your AAD as close as possible to what you landing area will be. Lets use your settings as you stated above. The landing area is 300 feet above the airport but yet you set the AAD for 450 above. Now, as long as the CYPRES works as stated you just set it's activation altitude for 900 feet AGL. If I remember correctly the CYPRES can fire at up to 1,200 ft AGL if you are going through the opening sequence at about this time (example pull at 1,500 ft). Now raise these numbers 150 ft...1,350 and 1,750 respectively. I would really be hoping to not have a need to "take it a little lower" for whatever reason and especially hope not to have a snively opening. On the other hand, if you set the CYPRES for and altitude lower than the landing zone....well you get the idea. Just some things to think about I guess.
Renaud SMA #9
"Mind is like parachute. It only functions when it's open."
