Katrinka
Skydive Arizona questions
folks!
I need advice from those who train there and use their jump ticket packages...
1. can i do 7-8 jumps a day with a coach without being on each load or every second load???
2. did you use jump packages to cover your coach slot? did you buy a separate package to do this?
thanks...
and any suggestions are appreciated!
Its time to rock&roll.
7-8 jumps a day: usually not a problem, although in summer, things are slower, especially in the week. If you plan on coming between now and May, should be easy (mind you, I dont visit the DZ during weekdays except during boogies, but I cant see it being a problem in fall-winter-spring).
As far as jump packages, you'll need to talk to Manifest for that. They have a couple different packages, some are only for your jumps, other are for blocks. And on top of that, some of the coaches may have package deals setups already.
Are you planing to just show up and find a coach, or do you have a plan already? You may want to check with him/her if you do.
Remster
