Bushmasta 0 #1 August 25, 2002 How is this done? And what is it exactly? any tips? Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #2 August 25, 2002 You refering to under canopy? This is done with the brakes partially applied - just pull one a little further down, and let one up a little. Do a search in the canopy control forum - there should be plenty there.____________________ Say no to subliminal messages Quote Share this post Link to post Share on other sites
Cornholio 0 #3 August 25, 2002 Wow..I was just looking this up today and bookmarked that thread. Billvon sums it up best: QuoteImagine two turns. The first one, you just pull a toggle down. You turn quickly, lose a lot of altitude, and come out of the turn with a lot of speed, more speed than the canopy normally gives you at full flight. The canopy gradually slows down to normal glide. The second one, you start with one toggle and bring the other one in gradually, until at the end of the turn you have both toggles most of the way down. The canopy comes out of the turn with _less_ speed than normal, and once you let go of the toggles, the canopy must speed up to get back to normal speed. Between these two extremes is an amount of opposite toggle that will not cause the canopy to slow down _or_ speed up; when you come out of the turn you will be at normal flying speed and can flare immediately. This my definition of a perfect flat turn. How do you practice this? Try it up high. When you complete the turn, immediately let both toggles up to full flight. If the canopy starts out flat, then dives when you let go of the toggles, you used too much opposite toggle. If the canopy starts out in a dive, then recovers after a few seconds, you used too little opposite toggle. If the canopy just shakes a bit then flies along happily, neither diving nor flattening back out, you used just the right amount of opposite toggle. >Other than NOT PUTTING MYSELF IN THAT SITUATION AGAIN, is there > anything else I could have done to help that landing? Try the above; another alternative would have been to turn less on approach and more during the flare itself. However, on the plus side, you took a potentially deadly situation and turned it into a minor sprain. That exact scenario injures and kills many people every year; good job at having the skill to keep yourself intact. I wish more people took the time to develop that skill. Butthead: Whoa! Burritos for breakfast! Beavis: Yeah! Yeah! Cool! bellyflier on the dz.com hybrid record jump Quote Share this post Link to post Share on other sites
jessefs 0 #4 August 25, 2002 Could you put up a link to that post you bookmarked?? Thanks jesse <* Spread the Love! *> Quote Share this post Link to post Share on other sites
Cornholio 0 #5 August 26, 2002 No problem, although there isn't much more there. http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=172357; Butthead: Whoa! Burritos for breakfast! Beavis: Yeah! Yeah! Cool! bellyflier on the dz.com hybrid record jump Quote Share this post Link to post Share on other sites
