Hold a stall for a while(2 to 5 seconds) and it will turn into a dynamic stall. The dynamic stall is as I described in the earlier post. The canopy will dive to one side, the back corners will touch, the canopy will then dive to the other side, the lines will go slack, and you will feel like a rag doll... The canopy will dive to each side. for example to the right, then to the left. The only way to recover it is to turn it to the side it is diving to... i.e. when it dives to the right bury the right toggle. Like I said earlier, do it high if you want to try it. It does make quite an impression on the person doing the stall and the people watching it.
As to the nose slider, if it is not hot knifed, it rides about 5 feet below the nose if I remember right. it doesnt come all the way down. That mod was something Jim Handbury showed me at the 76?77? nationals. I am not sure it made much difference, but the theory was that the nose could open more enabling more stable flight. Did the canopy you jumped have the nose slider(webbing with grommets across lines 2 and 3) along with a regular square type slider?
.....line 1
..... x
...x.....x
line2 line 3
(Sorry for the bad ascii art)
Did you do anything with the steering lines to stow them? If i recall the manual shows a pack job very similar to a flat pack with a square. You lay the canopy flat, with a single keel there would basically be three pieces of material laying flat from the tail to the nose. Then you s fold the canopy from the tail to the nose on each line group, and spread the nose to catch air. Is that how the manual shows to pack it? If i was there I could show you some packing techniques, but I wouldn't want to describe them without demonstrating....[;)
Edited to add:
normal stall recovery instructions...
murrays 0
QuoteThe canopy will first stall sort of like a square. You feel it get mushy then start to fall back. This is a normal stall. To recover from a normal stall just let the toggles up slowly....
Thanks for that information....I'll have to try it out..up high.
QuoteAs to the nose slider, if it is not hot knifed, it rides about 5 feet below the nose if I remember right. it doesnt come all the way down. That mod was something Jim Handbury showed me at the 76?77? nationals. I am not sure it made much difference, but the theory was that the nose could open more enabling more stable flight. Did the canopy you jumped have the nose slider(webbing with grommets across lines 2 and 3) along with a regular square type slider?
See the attached...yes, it has the slider as well as the strap. The strap stayed very close to the canopy as you can see from the photo. I didn't experience any inclination of the nose to fold under. Did this mod help in other ways?
The pack job is as you describe it. I stowed the excess loose steering lines in rubber bands near the cascades on the steering lines. I also stowed the strap in a rubber band that was attached to the front keel line. The strap didn't move downwards very far from there.
I was pretty nervous under this canopy and paying very close attention to my rate of descent. I wanted to be sure it would land me safely or I would have chopped it.
Thank-you very much for all of this information.
Murray
"No tyranny is so irksome as petty tyranny: the officious demands of policemen, government clerks, and electromechanical gadgets." - Edward Abbey
Be sure you open high. It is a very interesting experience.
>I didn't experience any inclination of the nose to >fold under. Did this mod help in other ways?
I wouldn't hotknife the nose slider, if it is not already done. I think we were just trying to wring more performance out of a low performing canopy(but it was hot at the time). The nose slider will not come down very far. That is normal.
>excess loose steering lines in rubber bands near >the cascades on the steering lines. I also stowed >the strap in a rubber band that was attached to the >front keel line. The strap didn't move downwards >very far from there.
That is a factory pack job. Sounds like you did everything. Always make sure the steering line stows near the cascade clears the rubber band after opening. Once I had a steering line stuck in the rubber band, that poped out on final, and the canopy did a 180. Really scared me, and everyone watching.
>I was pretty nervous under this canopy and paying >very close attention to my rate of descent. I >wanted to be sure it would land me safely or I >would have chopped it.
You should be nervous. They are scary canopies. I much perfer my stilletto or sabre. (I am way to fat to try jumping my dactyl, but if I could find a double keel one .... hmmm)
You are very welcome. I hope you enjoy jumping a piece of history. I never jumped a dactyl with a hand deploy or collapsible pilot chute. I always used a spring loaded pilot chute with a ripcord.
jbrasher 1
This was 25 years ago so there is a good chance I'm blowing smoke but that's what I remember.
We were putting students out on double-keels and had several land in the lake (after the 1st or 2nd Elsinore flood) and at first we thought it was only women that had this happen (blondes?). They would steer away from the lake and land in it. Naturally we were wrong.
My only jump on a single keel ended successfully after I promised God I would never jump another single-keel again.
I was jumping a Parafoil 252 (too big for me then) and wanted to experience what was so good about the Paradactyl.
Small toggle movements (seemed?) to cause very radical/violent canopy movements/folding. It was also a turbulent day and all in all I was glad to get it over with
The buddy I borrowed the single keel from was also using my rig for that jump and he wasn't at all satisfied with my large canopy; he just didn't talk to God.
Red, White and Blue Skies,
John T. Brasher D-5166
D-12855
jbrasher 1
Ben was upset and didn't want to ground him for life like he'd said he would because Larry was on staff.
So he had to jump T10's for a month.
I remember him landing next to me on one of those jumps and his peg stuck in a gopher hole and he just went BONG; I swear I could hear the vibrations
Sparky
wmw999 2,643
Personally, when you get to that point in weight savings, you have to consider the importance of going to the bathroom...
Wendy W.
and could land that thing just about anywhere he wanted. Inspired me to get a Dactyl of my very own.
Another guy that jumped triangle canopies exclusively was Bobby Vee at Coolidge. I can't remember if it was a Delta II or a Dactyl but it hurt to watch him land that thing in that high desert air. His landings consisted of a loud thump and a cloud of dust.,
wmw999 2,643
Wendy W.
QuoteJim still jumps here in Houston, although he hurt his back at Rantoul last year, and I haven't seen him other than visiting recently. He said Larry actually got him into Skydiving when they were both in Pennsylvania...
Wendy W.
That's great Jim still jumps, hope his back heals fast. Hope he didn't do it jumping that Dactyl.
QuoteAnother guy that jumped triangle canopies exclusively was Bobby Vee at Coolidge.
Before he started jumping "triangle canopies" Bobby was 6' 4" tall.
Sparky
murrays 0
Murray
Also, regarding the strap....if it hasn't been hotknifed should it stay up near the canopy or come down the lines?
Murray
