Pulling both drogue release handles before making an emergency exit is the proper procedure for a Strong rig. The drogue on the Strong system does not collapse until the canopy comes out of the bag, so the fully inflated drogue would still do its job in this case.
The Vector drogue collapses as soon as it is released, so pulling the drogue release handle before exit will only result in a delayed main canopy deployment (the drogue will be collapsed sonn after being thrown).
Pulling the drogue release handle(s) on a Sigma rig before exit will do nothing, since the curved safety pin keeps the straight main closing pin in place until the drogue is set.
As far as practicing emergency exits, I think expedited exits from lower altitudes with another TM or an experienced jumper who has made tandem exits on that equipment from that particular aircraft are worth the effort. I would make them no lower than 5500 FT - no sense in creating an emergency situation while training to prevent one. I would also take the time to do a full hookup and at least tighten snugly and evenly.
I have had two tandem emergency exits, both from 4000 FT. The first was an experienced student (8th tandem - 4th with me), and the second a first timer. In both cases we had plenty of time to completely hook up and tighten down - it did not take long at all.
You can post now and register later.
If you have an account, sign in now to post with your account.
John
