Pull priorities remain the same: Pull, Pull at the right altitude, Pull at the right altitude with stability.
I MUST pull in order to survive
I NEED to pull at the right altitude, no matter what my body position
I WANT to pull at the right altitude with stability
lug 4
Good question.
Some of this is repeating what others have said already but it does rase a question of my own in the fourth paragraph.
If a student can not answer yes to any one of the fallowing: C I A (Comfortable, In control or Altitude aware), they should work towards the level to where they can yes to all and give themselves five seconds to do so. After five seconds has elapse and they still can not say yes to any one of the C I A’s then they should pull.
As for loss of Instructor on two instructor jumps where the student loses one of their instructors they should continue the skydive with one instructor and pull at the altitude according to the dive flow. If they were to lose both instructors they should pull, now.
On release skydive with one instructor and the student loses them, they need to ask themselves are they C I A and if they can answer yes they should continue with the skydive and pull at the altitude according to the dive flow.
As for Category C skydives, the release, where the student loses both instructors seems to kind of a gray area, so I am interested in what everyone else is doing through out the U.S. I have been instructing them, during the ground training, to fallow the C I A, five second rule format in this situation.
Memento Mori
markbaur 0
This is the problem with CIA: it gives priority to the least important element. I don't think there are any instructors who want to apply the 5-second rule to altitude awareness, and yet that is exactly what is said above -- even though you didn't intend it, you taught it.
Try instead AIR:
Altitude aware. You can see your altimeter and you know it's working.
In control. If not, and altitude permits, 5 seconds to get that way.
Relaxed and comfortable. You don't have to continue freefall if you don't want to.
You could make your explanation even simpler by stopping after "In control."
Where in the SIM or IRM is CIA?
Mark
lug 4
I see what you are saying I’ll try using AIR. Just like the circle of awareness, the first thing a student should be doing is checking their altitude when they are given the hand signal or they do it on there own.
I have also not found C I A in the SIM, but for me it came from my AFF certification course where the class was instructed by the evaluator to teach it during the ground school for the level 3 jump. It is however found in the video tape I received with my AFF package titles “USPA AFF Level Three Training” Second Edition. I feel that if this information about C I A on the tape was incorrect or out dated then the USPA would have taken it out before the wide distribution to the candidates as part of their AFF package.
Things change over time so I am not sure if even the USPA is including a video in the AFF candidate package since the IRM’s introduction.
Memento Mori
Your writing explains better than mine -- point comes across better
Sure it does. If not, you are NOT altitude aware. I breif this scenario with my students. I also concur with Chuck.
So what do you do if the instructor is not anywhere in sight and you are at 4,000'? (Assuming I have them pulling at 5) I want the right answers or we do not jump.
