Zennie 0 #1 August 19, 2001 I've got close to 100 jumps on a Sabre 150 now so I'm getting pretty familiar with it's flying characteristics. But yesterday my canopy did something that I hadn't seen before (except in a downwinder)... I had practically no "bite" when I went to flare. I just kept pulling it farther and farther and it just kept sinking & sinking.My normal flare is generally a little surf-ish. I hit it pretty close to the ground to level it off and then bleed off the forward speed. This time I never got that level-off. Wound up doing a Fred Flintstone stop with my heels.I'm still perplexed as to why I didn't get any grab. It was a little windier. I was playing with generating some forward speed with my front risers and I was slightly crosswind, but nothing too substantial. I was thinking crosswind was the culprit, but I've landed it in no-wind without probs. I wouldn't think a crosswinder would take anything more from you flare-wise than no-wind, but maybe I'm wrong on that.Thoughts?------------Blue Skies!Zennie Quote Share this post Link to post Share on other sites
freeflir29 0 #2 August 19, 2001 Any chance you were having to put in some correction to keep the canopy on heading? If you were you may have (unnoticed) bled off some of the speed. When you get too slow you get out of the envelope for the control surface of the wing (Brakes) to work properly. Just a thought."Say sweet thing...Can I buy you a fish sandwhich?"-Leon PhelpsClay Quote Share this post Link to post Share on other sites
Kris 0 #3 August 19, 2001 The same thing happened to me a couple of weekends ago. Some of the guys on the ground watched it happen. I came in and at about 50-feet I stopped moving forward and just started sinking and no amount of flare happened at the ground. I managed to stand it up but I hit pretty hard. The conclusion from those that saw it was that I caught a down-rotor when I came in on final. Wind near the hangars on a hot, sticky, Oklahoma day can be fun sometimes. (not)Kris Quote Share this post Link to post Share on other sites
Zennie 0 #4 August 20, 2001 QuoteWind near the hangars on a hot, sticky, Oklahoma day can be fun sometimes. Houston's about the same. That would make some sense. The winds were a little shifty that day and I was close to the hangar.The crosswind adjustment theory also makes some sense. It's pobably one of those "all of the above" situations.------------Blue Skies!Zennie Quote Share this post Link to post Share on other sites
freeflir29 0 #5 August 20, 2001 "It's pobably one of those "all of the above" situations."I'd bet my paycheck on that!"Say sweet thing...Can I buy you a fish sandwhich?"-Leon PhelpsClay Quote Share this post Link to post Share on other sites
ramon 0 #6 August 20, 2001 I saw several people busting there butt yesterday...It was bumpy ramon Quote Share this post Link to post Share on other sites
billvon 3,176 #7 August 23, 2001 >I had practically no "bite" when I went to flare. I just kept pulling it farther and farther and it just kept sinking & sinking.Did you land near trees/buildings? That sounds like classic wind shear. You had 20kts of airspeed as you were coming in, but then the obstacles blocked some of that wind, so you started your flare with only 15kts of airspeed, resulting in a mushy flare. An extreme case of that put me in a wheelchair once - I tried to land a PD190 twenty feet from a treeline on a windy day.-bill von Quote Share this post Link to post Share on other sites
Zennie 0 #8 August 23, 2001 QuoteDid you land near trees/buildings? That sounds like classic wind shear. Yeah I was right near the hangar, but the hangar was to my west and the winds were coming from the south/SE although they occasionally shifted to the SW. Wouldn't think that would cause a problem given my location but maybe there was some swirling.------------Blue Skies!Zennie Quote Share this post Link to post Share on other sites
Kris 0 #9 August 23, 2001 Yup Zennie, you might have caught a rotor off of the hangar.Mine was a double-fault: Landing too close to the hangars along with being heat-sick / low blood sugar at the time. I knew I shouldn't have jumped but at the time it was easier to leave the airplane after pitching the last student then it was to climb back in. On landing the ground was coming straight up at me (yes, the canopy was open, heh) and it felt like I was flaring with two limp noodles but I did flare.I guess the fact that it was easier to leave than to climb back in should have been my first clue. Kris(Older and hopefully wiser now) Quote Share this post Link to post Share on other sites
