jephprospect 0 #1 December 1, 2008 Hey folks, I'm on jump 38 and still having issues jumping with just 1 person and doing docks with them. I'm getting super frusterated. Is this normal? It seems other people are learning and progressing faster then me. Everyone always says tunnel time helps with everything but would it help for docking since it's so small? Thanks, Jeff Quote Share this post Link to post Share on other sites
stormywinters 1 #2 December 1, 2008 NO MAN! Tunnel time will never help ur boatin skills!! Quote Share this post Link to post Share on other sites
kirkverner 0 #3 December 1, 2008 The tunnel can absolutely help with taking grips. This is a common problem for beginning belly flyers. Next time start taking grips when you are slightly low so that you reach up for the grips. Do your best to not get frustrated, skydiving is an infinite learning process and requires diligent practice. ParacleteXP Quote Share this post Link to post Share on other sites
tetra316 0 #4 December 1, 2008 Quote Next time start taking grips when you are slightly low so that you reach up for the grips. Interesting. Can you explain? I've never heard this before. Quote Share this post Link to post Share on other sites
DON321 0 #5 December 1, 2008 Quote The tunnel can absolutely help with taking grips. This is a common problem for beginning belly flyers. Next time start taking grips when you are slightly low so that you reach up for the grips. Do your best to not get frustrated, skydiving is an infinite learning process and requires diligent practice. This is Incorrect!! You Never want to REACH while trying to dock you wil only find yourself everywhere else but docking when reaching.... The tunnel is a great place to learn, expensive but well worth it.... you will progress fast with tunnel coaching, but sometimes you will need to tweak what you learned a hair when it comes to a skydive since your now wearing a parachute on your back..... Quote Share this post Link to post Share on other sites
tetra316 0 #6 December 1, 2008 You might want to consider who is posting this advice before you blatantly declare it wrong Quote Share this post Link to post Share on other sites
diablopilot 2 #7 December 1, 2008 Quote Quote The tunnel can absolutely help with taking grips. This is a common problem for beginning belly flyers. Next time start taking grips when you are slightly low so that you reach up for the grips. Do your best to not get frustrated, skydiving is an infinite learning process and requires diligent practice. This is Incorrect!! You Never want to REACH while trying to dock you wil only find yourself everywhere else but docking when reaching.... The tunnel is a great place to learn, expensive but well worth it.... you will progress fast with tunnel coaching, but sometimes you will need to tweak what you learned a hair when it comes to a skydive since your now wearing a parachute on your back..... You just told Kirk Verner how to take a grip. Kirk, you taking notes?Seriously, the tunnel is a great place to work on all those "last 3 feet type things" although in Kirk and Joe's tunnel, it's more like the "last 10 feet type things"!---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
VanillaSkyGirl 6 #8 December 1, 2008 Hello Don, you might want to do a search on "Arizona Airspeed" and search who "Kirk Verner" is before responding further. His profile can be found here: http://www.onthelineskydiving.com/CoachProfiles.html Kirk is one of the founding members of Arizona Airspeed and a very highly experienced RW coach, both in the sky and tunnel. He is also extremely humble. If he writes or says something, it would be best to try to listen and learn. Quote Share this post Link to post Share on other sites
matthewcline 0 #9 December 1, 2008 If I recal properly, when new at this grip taking thing, using a high grip will keep the fall rate going for the newer jumper. You and I may fly a Mantis type style and have learned to maintain our fall rate, for a new jumper reaching out an inch or two may cause just enough of a body change to either pop up and/or back slide out. It needs not be a real high grip just at the ear level is usually enough. This will also help keep the head up and aides in the eventual transition to a good eye level mantis. Now I defer back to Kirk, since I am way our of my element now! Matt P.S. I could be all wrong here too! An Instructors first concern is student safety. So, start being safe, first!!! Quote Share this post Link to post Share on other sites
skittles_of_SDC 0 #10 December 2, 2008 Quote Hello Don, you might want to do a search on "Arizona Airspeed" and search who "Kirk Verner" is before responding further. His profile can be found here: http://www.onthelineskydiving.com/CoachProfiles.html Kirk is one of the founding members of Arizona Airspeed and a very highly experienced RW coach, both in the sky and tunnel. He is also extremely humble. If he writes or says something, it would be best to try to listen and learn. Why you sweatin' DON321, he clearly has MAD SKILLZ. Airspeed Schmarspeed. Kirk only has a handful of championship medals. Don probably has a box full. Quote Share this post Link to post Share on other sites
BlueHaze 0 #12 December 2, 2008 And people wonder why Kirk does not post much here on DZ.com. Quote Share this post Link to post Share on other sites
stormywinters 1 #14 December 2, 2008 U can never say the right thing here??? GREAT!! Quote Share this post Link to post Share on other sites
AggieDave 6 #15 December 2, 2008 Quote This is Incorrect!! You Never want to REACH while trying to dock you wil only find yourself everywhere else but docking when reaching.... When you're done teaching Kirk how to fly RW and take grips, would you come to the Swooping forum and teach JT how to do a distance run?--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
CarloC 0 #16 December 2, 2008 Priceless (2) Blue ones!!! Quote Share this post Link to post Share on other sites
DARK 0 #17 December 2, 2008 ah come on lads take it easy on the guy those 2300 jumps do look deceptively like 23 ah no it is an easy mistake to make to just reply with what your coach told you without thinking very funny though Quote Share this post Link to post Share on other sites
CarloC 0 #18 December 2, 2008 Add a zero in that, its twenty three thousand jumps 23.000 Later Quote Share this post Link to post Share on other sites
hparrish 0 #19 December 2, 2008 Yes I'm certain that the 23,000 jumps next to Kirk's profile is inaccurate. It's probably more like 25,000 + by now right? But what does Kirk know.........He's just a Tunnel Rat anyway. Quote Share this post Link to post Share on other sites
michalm21 2 #20 December 2, 2008 Quote Quote The tunnel can absolutely help with taking grips. This is a common problem for beginning belly flyers. Next time start taking grips when you are slightly low so that you reach up for the grips. Do your best to not get frustrated, skydiving is an infinite learning process and requires diligent practice. This is Incorrect!! You Never want to REACH while trying to dock you wil only find yourself everywhere else but docking when reaching.... The tunnel is a great place to learn, expensive but well worth it.... you will progress fast with tunnel coaching, but sometimes you will need to tweak what you learned a hair when it comes to a skydive since your now wearing a parachute on your back..... Hahahaha This is priceless. A 100 jump wonder telling Kirk is wrong at RW. Classic. Quote Share this post Link to post Share on other sites
skittles_of_SDC 0 #21 December 2, 2008 Well to be fair if someone had never heard the name kirk verner they might think that the 25,000 was a straight up lie. Quote Share this post Link to post Share on other sites
hparrish 0 #22 December 2, 2008 kind of like your 175 jumps? Quote Share this post Link to post Share on other sites
DARK 0 #23 December 2, 2008 damn it now i did it i was actually saying 23000 in my head as i typed that, damn sleeping pills Quote Share this post Link to post Share on other sites
skittles_of_SDC 0 #24 December 2, 2008 Quote kind of like your 175 jumps? WTF was that little comment? I meant because 25,000 is such a high number. Quote Share this post Link to post Share on other sites
DrewEckhardt 0 #25 December 2, 2008 Quote Quote The tunnel can absolutely help with taking grips. This is a common problem for beginning belly flyers. Next time start taking grips when you are slightly low so that you reach up for the grips. Do your best to not get frustrated, skydiving is an infinite learning process and requires diligent practice. This is Incorrect!! You Never want to REACH while trying to dock you wil only find yourself everywhere else but docking when reaching.... Nah (being fully aware of the other posts and who wrote them). You just need to learn to compensate with the rest of your body. Reaching a foot or two in any direction is faster than accelerating and stopping all 200 pounds of you rig and beer gut so you don't have to reach. Especially if you're connected to one or more other people that you'd have to drag along with you. That's almost work. Quote Share this post Link to post Share on other sites
