GLIDEANGLE 1 #1 December 27, 2012 Are you aware of any DZs which modify the student wing loading if the weather gets really hot? If the weather gets hot, do the weight limits come down? If so: ----what is the temperature threshold? ----what is the % decrease in loading?The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
DARK 0 #2 December 27, 2012 QuoteAre you aware of any DZs which modify the student wing loading if the weather gets really hot? If the weather gets hot, do the weight limits come down? If so: ----what is the temperature threshold? ----what is the % decrease in loading? Not aware of any dropzones that do this, I understand what happens when the temperature rises but you can only baby people so much, enough is enough imo. If they cant land an already lightly loaded canopy in warmer weather then maybe they are one of the students we should weed out of the sport there and then. Quote Share this post Link to post Share on other sites
Andy9o8 2 #3 December 27, 2012 QuoteDecrease student wing loading when HOT? If the adjective refers to women: yes, it sometimes does work that way, unfortunately. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #4 December 27, 2012 I consider mostly the winds when picking out a student canopy. I think I'll start considering the temp on hot summer days, too. Thanks. Quote Share this post Link to post Share on other sites
holie 0 #5 December 27, 2012 ... just have a look at http://en.wikipedia.org/wiki/Density_altitude ... and never forget to think about elevation, atmospheric pressure and temperature while choosing the canopy (of your student). Quote Share this post Link to post Share on other sites
davelepka 4 #6 December 27, 2012 If a DZ needs to have a policy in place to upsize strudents on a hot day, their student WL are too high to begin with. The idea of a low WL for a student is to build a margin for error into their canopy choice, and if a hot day can erase that, there's not enough margin. By all means, instructors should be considering the day when picking student canopies. If the day is hot and humid, err on the conservative side, and if it's a chilly fall day with a steady breeze, maybe one size smaller could be employed, but both sizes need to be large enough to be 'too big'. You have to remember that there's no harm in a canopy that's too large, if you're pickign between two sizes, you're not going to hurt anyone by 'going big'. It's easy to forget that flying a canopy is something that takes some getting used to, but talk to some newer jumpers about their recent downsizes, and you'll get some perspective. When a guy with 50 jumps describes a 190 as 'quick, with responsive turns', you get the picture that a student will be literally thrilled with a 280 at .6 to 1 WL. Quote Share this post Link to post Share on other sites
kallend 2,106 #7 December 27, 2012 Agreed. You need to be about 45 degrees (F) above "normal" temperature to get a 5% increase in landing speed.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
faulknerwn 38 #8 December 27, 2012 On the really hot days in Texas we have sometimes had the opposite problem. Downsized a student a bit ( still below 1-1 though ) because twice in one weekend we had students take a half hour to land. One student pulled at 5500 and got up to 7500 before he started coming down. It's common even on my 120s on those days for me to gain altitude on my downwind leg. Multiple times after letting off double fronts I had so much lift I didn't have to flare at all. The thermals get crazy in tx when it's hot. The tandem masters have learned where to fly so they can actually come down and land. I once got a ways out on a crw jump but covered 3 miles from 3000 feet by following the thermals back from the highway. Fun stuff! Quote Share this post Link to post Share on other sites
chedlin 0 #9 December 27, 2012 At the same DZ I was in the playground area to the west. I went about 2000' back and forth in a line 3 times under the student 270 and only lost about 50' in altitude. I was still on the radio and the instructor had me pull a 360 to get down a bit. It might be fun to nearly paraglide under a skydiving canopy if traffic and time permits this coming summer. Are the thermals similar at San Marcos? Quote Share this post Link to post Share on other sites
excaza 1 #10 December 28, 2012 Quote Agreed. You need to be about 45 degrees (F) above "normal" temperature to get a 5% increase in landing speed. Another 45 degree rule! Quote Share this post Link to post Share on other sites
kallend 2,106 #11 December 28, 2012 Quote Quote Agreed. You need to be about 45 degrees (F) above "normal" temperature to get a 5% increase in landing speed. Another 45 degree rule! Yes, but this one is different in C.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
dthames 0 #12 December 29, 2012 QuoteAt the same DZ I was in the playground area to the west. I went about 2000' back and forth in a line 3 times under the student 270 and only lost about 50' in altitude. I was still on the radio and the instructor had me pull a 360 to get down a bit. It might be fun to nearly paraglide under a skydiving canopy if traffic and time permits this coming summer. Are the thermals similar at San Marcos? Those farm fields with dark earth exposed and a hot sunny days, yes you can expect some thermals. Around the Dallas DZ are some really dark fields and I know they will give you a ride. San Marcos has some farm fields as well. I don't know if the soil is dark or what type of year crops will not cover the ground. Ask around the DZ when you get a chance. The locals should know.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
nigel99 568 #13 December 29, 2012 No, but yesterday I learnt that we lower the maximum weight limit for tandems according to the temperatureExperienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
pchapman 279 #14 December 29, 2012 Quote Agreed. You need to be about 45 degrees (F) above "normal" temperature to get a 5% increase in landing speed. Yeah, that sounds about right. For an article I once wrote, I worked out the following approximations for the relationship between temperature, altitude, speed, and canopy size: +10 deg. C (=18 deg F) = +1200’ altitude = +1.8% airspeed = 3.6% reduction in canopy area = a need for a 3.6% increase in canopy area to fully counteract the density effect For simplicity I tend to round off the percentages even though it slightly overstates the effect of temp or altitude: +10 deg. C (=18 deg F) = +1200’ altitude = +2% airspeed = 4% reduction in canopy area = a need for a 4% increase in canopy area to fully counteract the density effect (These are linear approximations of non-linear relationships, but reasonable over typical ranges.) Quote Share this post Link to post Share on other sites
ChrisD 0 #15 January 13, 2013 What a great question!, Quote Are you aware of any DZs which modify the student wing loading if the weather gets really hot? If the weather gets hot, do the weight limits come down? If so: ----what is the temperature threshold? ----what is the % decrease in loading? You have the right to also ask this same question of the aircraft at your local DZO! Perhaps the next time your in a Cessna product and you see 5 other faces, the prudent thing would be to question this. CBut what do I know, "I only have one tandem jump." Quote Share this post Link to post Share on other sites
kenthediver 0 #16 January 14, 2013 On a similar topic, I jump at Ocana which is approx 2000 foot above sea level. I have been told my 260 Nav (I am a low number jumper) is the same as a 240 Nav at sea level. No reason to query it, just if you consider temp, maybe altitude above sea level needs to be considered? Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #17 January 14, 2013 Quote What a great question!, Quote Are you aware of any DZs which modify the student wing loading if the weather gets really hot? If the weather gets hot, do the weight limits come down? If so: ----what is the temperature threshold? ----what is the % decrease in loading? You have the right to also ask this same question of the aircraft at your local DZO! Perhaps the next time your in a Cessna product and you see 5 other faces, the prudent thing would be to question this. C Really? At my home DZ's me plus 5 would be a light load in our Cessna..... Caravan. Yes, I get your point. However, not all Cessna's are alike.The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #18 January 14, 2013 QuoteOn a similar topic, I jump at Ocana which is approx 2000 foot above sea level. I have been told my 260 Nav (I am a low number jumper) is the same as a 240 Nav at sea level. No reason to query it, just if you consider temp, maybe altitude above sea level needs to be considered? Of course elevation plays a HUGE role. However, in the case that I implied at the outset, we are discussing changes with temperature at a given DZ. If any DZ is experiencing sufficient changes in elevation to warrant thinking about canopy size....there are much bigger problems to deal with! (Think: earthquake, landslide, volcano, etc)The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
