Tandem tension knot - Just because it flies OK doesn't mean it lands OK
By
pchapman, in Tandem Skydiving
Quoteits very easy to judge from hind sight
The condition of that canopy was easy to judge fron any sight. I read the OP, and had pictures in my mind of what was happening. When I got to the end and opened the first pic, that was all I needed to see. Much, much worse than what I had pictured, and not even close to a 'landable' canopy for any tandem on any day. Not even close.
The fact that three other jumpers did a 'fly by' to see the mess, and more than one person found it noteworthy enough to take pictures says a lot about the situation.
normiss 858
This.
1000%
Repeatedly.
VideoFly 0
I know this may sound terrible, but I am just posing several questions. Might it be possible that in some instances, the decision to not chop a compromised, but possibly landable main, may involve thoughts of avoiding expenses of repacking a downed rig and the possible loss an expensive main canopy? Could an instructor fear ridicule for cutting a possibly landable main away? Might an instructor lack the experience and/or training to be comfortable cutting a compromised main canopy away?
Quotethoughts of avoiding expenses of repacking a downed rig and the possible loss an expensive main canopy? Could an instructor fear ridicule for cutting a possibly landable main away? Might an instructor lack the experience and/or training to be comfortable cutting a compromised main canopy away?
As to the costs, be it loss, repacks, or down time, any instructor or DZO who let's that be a part of the equation should not be in the tandem business. If you cannot afford the loss/repack/down time, then you cannot afford the lawsuit that could ensue from an injured passenger.
As to the ridicule, if you're not past the point in your life where the opinions of others matter so highly to you that it effects your decision making while dealing with malfunctions, then you lack the maturuty to be an instructor, and quite possibly a skydiver in any respect.
As for the training, every TI is required to have at least one cutaway as a prerequisite for the rating. Even without that, again, if you lack the fortitude to pull the handles, you should not be instructing or skydiving.
I understand the points you're making, but this is remedial stuff here. Like others have pointed out, the criteria of 'square' is taught during the FJC with regards to identifying a good canopy. This canopy clearly did not meet that criteria, yet this jumper chose to fly it to the ground, with an eldery passenger in the harness.
Between this, and the recent fataility in Uruguay, I have to wonder what the hell people are thinking. There should be page after page of posts, speculation, and what-if's in the wake of any incident. Simple obvious things like we see here and in Ururguay should never come into the equation.
It's like I said, when I read the OP, I had a picture in my mind of what the canopy looked like. It was similar to a canopy with one brake stowed, and the other pulled down to counter it, like a knot in the steering line alone. When I opened the pic, I was shocked at the condition of the canopy, and that anyone would think to land it. It's just dumb, and if you're going to do dumb things, this is what happens.
Where the hell did common sense go?
billvon 3,078
Yes. Even when properly assembled, maintained, packed and deployed, parachutes can malfunction.
>While I can appreciate that the decision to cut a main canopy away may include
>thoughts of the reserve not performing properly, a tandem instructor must make a
>quick and deliberate decision without second-guessing a reserve’s performance.
Definitely not. Any instructor (AFF or tandem) MUST understand and consider the additional risks incurred by deploying a reserve when it is not absolutely needed. They are not foolproof.
>I have seen tandem instructors land compromised main canopies, usually with
>satisfactory results, but that gamble may also place students into an unsatisfactory >situation.
Agreed - and that's true both ways. There is no one correct answer that covers all situations.
Rover 11
Quote>I think it is fair to say that the judgement made was poor to say the least . . .
Had a friend who cut away from a tension knot on his (Strong 520) tandem main. He later remarked it was probably landable. His reserve opened with a lineover. The outcome would likely have been worse than the one in this case, except he impacted in a mud puddle (rare in San Diego; he was very lucky.) Minor injuries to the student.
Was his judgment poor?
The fact that it was 'probably landable' means that it wasn't definitely landable. If there is shit happening, move on, and then deal with the hand you've been given. The fact that you have used this as a defence to what happened in the original post means that I question your judgement if you think that what occurred was justified.
BrianM 1
QuoteAs for the training, every TI is required to have at least one cutaway as a prerequisite for the rating.
The rest of your post is great, but that statement is incorrect. It varies with manufacturer. Strong and Jumpshack require one, UPT does not. I'm not familiar with other manufacturers.
While I can appreciate that the decision to cut a main canopy away may include thoughts of the reserve not performing properly, a tandem instructor must make a quick and deliberate decision without second-guessing a reserve’s performance. In the situation you described, I believe your friend made the correct decision. It was unfortunate that there was a problem with his reserve, but his good decision to cut away and the fact that the reserve “opened with a line over”, or should I say, may have been packed to open with a line over are two completely separate issues, which affected a single skydive.
I have seen tandem instructors land compromised main canopies, usually with satisfactory results, but that gamble may also place students into an unsatisfactory situation.
