skydiveoc 0 #1 August 24, 2012 All of a sudden our dz is seeing drogue attachment wear and even material failure on Sigma 2 340 canopies. The canopies range from 700 to 1500 jumps, have had new vectran line sets about 300 jumps ago. Anyone else having similar situations? Quote Share this post Link to post Share on other sites
camamel 0 #2 August 25, 2012 I have 15 Sigma 340 that have been reline with vectran and new colapsable slider two years ago ranging from 1000 to 1900 jumps with no similar problem. Slider doesn't last as long as before. I also had an issue with a green that was fading on one main, PD test it and everything was O.K. but doesn't look very good so I ask them to give me some credit to buy another one...witch they did. I have the same problem this year with an orange but after 1500 jumps I will have to live with it. Otherwise nothing at all with an average of one cut away per 2000 to 2500 jumps in the last 17000. Did your packers keep there t-shirt on when they pack?When you think you're good...this is when you become dangerous. Quote Share this post Link to post Share on other sites
skydiveoc 0 #3 August 26, 2012 QuoteI have 15 Sigma 340 that have been reline with vectran and new colapsable slider two years ago ranging from 1000 to 1900 jumps with no similar problem. Slider doesn't last as long as before. I also had an issue with a green that was fading on one main, PD test it and everything was O.K. but doesn't look very good so I ask them to give me some credit to buy another one...witch they did. I have the same problem this year with an orange but after 1500 jumps I will have to live with it. Otherwise nothing at all with an average of one cut away per 2000 to 2500 jumps in the last 17000. Did your packers keep there t-shirt on when they pack? We used to require T shirts on until we hired some part time Hooters waitresses to pack and now for safety sake we do not allow shirts on while packing. :) Yes shirts are on... Quote Share this post Link to post Share on other sites
jonathan.newman 1 #4 August 27, 2012 We seem to blow up our three sigmas a lot. Cells tear open from nose to tail. They are old, discolored, and faded. We've had pretty good luck getting them repaired at a rigging loft and back in service. Quote Share this post Link to post Share on other sites
skydiveoc 0 #5 August 27, 2012 These canopies are oldER but not that old. Openings were not that hard either when they gave. Quote Share this post Link to post Share on other sites
camamel 0 #6 August 31, 2012 Even if your packers keep there t-shirt on, if they are sweating a lot and put there face on the canopy to deflate it while packing it might be a cause! Here we put huge fan in the packing area to make sure this doesn't happen. Are you closed to shore in a salty environment? Do you make a pull test on the main fabric each year or at least on the oldest mains? That's all I can think. My last idea would be to contact UPT about it. Let me know if you find something. RichardWhen you think you're good...this is when you become dangerous. Quote Share this post Link to post Share on other sites
