altichick
Mark up problem...
Hi I tried to make a clicky link to this BPA document http://www.bpa.org.uk/forms/docs/Form%20215%20-%20BPA%20Reserve%20Sealing%20Method.doc
When you try to make it a clicky like this
The link gets changed to this
http://www.bpa.org.uk/forms/docs/Form20-%20BPA%20Reserve%20Sealing%20Method.doc
Which doesn't exist!! Help?? :S
Don't sweat the petty things... and don't pet the sweaty things!
I do believe that those "%20"s are really fouling things up, but more of a problem is that apparently you have to be a registered BPA member to access that form in the first place, so you may not be able to link to it anhwho.
When I try to go to www.bpa.org.uk/forms I get a 403 or "Access Forbidden" message.
Faster horses, younger women, older whiskey, more money.
Why do they call it "Tourist Season" if we can't shoot them?
I got a "page cannot be found" with that, Jack.
Yep -- because I hit the "Post Reply" when I intended to preview it to see if it worked.:$
See my revised post above.
I got it to work. Instead of copying and pasting the short cut from the page where all the documents are listed, I actually opened the document (no you don't have to join BPA - I'm not a member) and once the PDF document was open I copied the address from there. The basic issue is that there is spaces in the address.
"http://www.bpa.org.uk/forms/docs/Form 215 - BPA Reserve Sealing Method.doc" is what I put the mark up URL codes around.
"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy
That's correct. %20 represents a space. IE inserts those by itself when it sees a space in a URL. If you actually enter them they will often be interpreted as standard characters and you'll get a broken link. Always a good idea to have no spaces in your file naming convention.
Safe swoops
Sangiro
