bernard
clear and pull- safety
We all love skydiving but in a safe way. Following jump sequence may not occur according to my previous s/l instructor:
http://www.youtube.com/watch?v=7gAzRXsc6HQ
Personaly I loved the old caracter building method but for my daughter I prefered the Aff method (french version of it) simply to avoid such a sequence.
But anyway I insisted she learned to jump low, simply because a complete skydiver must learn to exit low.
Conclusion the ideal method is a mix of the old one and the Aff method.
Your opinion is welcome because we all know we must master low exits;);)
There's no way in hell I would ever get on a plane again with someone with one hand on the strut and one hand on their hackey. But yeah.. never do that again.
You can see for a split second that he does indeed launch from two hands on the strut - just freaks out and lunges for his hackey straight away afterwards.
OP: AFF or SL, doesn't really matter: if you do this on your clear and pull, then your opening will suck :P
"I'll tell you how all skydivers are judged, . They are judged by the laws of physics." - kkeenan
"You jump out, pull the string and either live or die. What's there to be good at?
Would it be fair to say that this sort of fumbling is less common for people who learned via static line? The only reason I ask is because you have to do several stable exits (in a row) on static line before they let you do your first hop-n-pop, whereas on AFF unstable exits are more likely to be 'soaked up' by the instructors.
-This post (and all my others, in fact) comes with a healthy disclaimer that I know nothing about instructing, or anything. Apologies in advance for any offence caused.
Anyone who's trained SL students for any length of time has seen plenty of unstable hop & pops. :S[:/]
That grabbing the hacky on the step shows a real lack of confidence on the student's part. He definitely needs a LOT more re-training.
Wasn't the biggest problem that he dearched as he launched? I would have thought a nice hard arch would have made a hurried but good exit?
Experienced jumper - someone who has made mistakes more often than I have and lived.
The video shown could have been an AFF trained student on a hop and pop as easily as it could be a SL student on their first clear and pull. If you fail to do what you are taught, you will have bad form. i dearched on my first AFF jumps when I pulled, and I dearched on a SL practice pull. It you do it in SL, you are not at "terminal" which might make it a little less violent.
AFF has some benifit that SL does not and the other way around is also true. Someone has previously stated a mix might be the best and I agree.
Instructor quote, “What's weird is that you're older than my dad!”
I've got more static line exits than you have jumps :) not because of military but because I struggled with drcp. But I still remember doing a 10 second delay from 4k and a girl who'd gone through AFF was freaking out about doing a clear and pull from 4k.
I still think a hard arch would have fixed most of his issues.
Absolutely. :)
Back when we trained a lot of S/L, you'd see students do great arches for their PRCP jumps, then curl up and turn turtle on their first free fall.
One day I put a young man out on his first free fall. The pilot, a very experienced instructor himself, asked "How'd he do?"
I replied "The usual."
Pilot said "Rolled on his back and dumped?"
I said "Yep, you got it.":D:D
Absolutely. :)
:D:D
That was AWESOME, compared to my HnP on jump 18.
Went unstable much like video guy, but deployed BETWEEN my legs, and spun not once but TWICE through my risers.
I had lines wrapped around my right ankle and my arm was twisted between the right side front and back risers.
I unwrapped my ankle, dragged my arm out of the risers, (got burns on both), looked at my canopy (which is now square and stable) looked at my risers both were twisted around each other front to back.
Then I looked reached grabbed and pulled then cleared my cables and landed a nice big white fluffy cloud like reserve.
Walked back in to the hanger, sat down for 30 mins went up to an instructor and said. Let go back up.:ph34r::ph34r::ph34r: that was almost 1200 jumps ago and it's STILL a vivid memory:)
My Life ROCKS!
How's yours doing?
F-ing great story. B|
They must not have had bowling in OZ back then. :P:D
It's a decision the instructor still regrets to this day ::D:D:D:D
My Life ROCKS!
How's yours doing?
Sit on the ground and knit then.
He isn't the first student who panicked on a clear and pull, dearched and lost stability, and then did a rushed pitch. He won't be the last one to do it either.
He didn't have his hand on his hackey on the step, he just rushed to pull when he should of focused on arching.
"The restraining order says you're only allowed to touch me in freefall"
=P
Practically every S/L student on their first freefall I've ever seen leaves the step immediately reaching to pull. It's the natural lizard-brain reaction to not being hooked-up for the first time. It's the arch that's everything.
If you think back to the jumps right before, when you do have to pull the practice device, if you don't go for it pretty fast, you will be snatched by the opening and miss the pull. So, it has been trained in, to hurry. I thought I did fair. maybe a bit quick still...
http://www.youtube.com/watch?v=xBH1Znjew6A
