skreamer 1 #1 December 9, 2001 Here's a question for the esteemed Swooping Moderator - Chuck (yep I can suck up with the best of them! Watching some experienced canopy pilots doing a carving front riser turn, I have noticed that they raise the opposite leg when initiating the turn. I presume this is to put more body weight on the side of the harness that they are risering (ie raise right leg if hanging on left riser). Does this really make any difference to how the canopy dives (ie translating into more forward speed?)?Will Quote Share this post Link to post Share on other sites
RemiAndKaren 0 #2 December 10, 2001 [looks around, doesnt see any canopy nazi's in this banned land]pssst, kid! I've got something sweeeeet for ya... all the cool kids are jumpin 'em now..... first jump is free..... and dont listen to you so called friends that say 2.8 is a high wing load....RemiMuff 914 Quote Share this post Link to post Share on other sites
PhreeZone 20 #3 December 10, 2001 Shifting the weight can allow for the turn to be completed faster. A faster, sharper turn can result in higher speed on the landings, but it can also cause your body to swing out more and allow for a faster sink rate in the turn. If you not expecting the difference, you can easly find your self low in the corner.I want to touch the sky, I want to fly so high ~ Sonique Quote Share this post Link to post Share on other sites
freeflyguy 0 #4 December 10, 2001 On the higher loaded canoies, a harness turn will cause a very fast rate turn.I opened at 9k on that Xaos Friday and just played with some things.. (it is loaded at 2.1). A pure harness turn with no riser input will gradually increase speed until you are smoking. If I took it to 360 degrees, it would lose about 750 feet, and by the end have good speed. Not as much as a riser turn though. I have seen Andy do a pure harness turn on a canopy loaded at around 2.9 and it results in a fast turn and swoop. I think the advantage of a harness turn is it does not mis-shape the canopy, like a front riser. But it is not as easy to fine tune as having both risers in your hands. The speed gain is limited too. After a 360 on mine, the pressure builds so much, it won't really keep getting faster. You can only apply so much pressure with your harness.Try it. The lower the wing loading, the less you will get, but just about any canopy will get some harness turn. Quote Share this post Link to post Share on other sites
ramon 0 #5 December 10, 2001 on a really highly loaded canopy you can initiate a spiral with just shifting your weight in the harness.r Quote Share this post Link to post Share on other sites
AggieDave 6 #6 December 10, 2001 I have a fairly light wing loading (1.4), well would that make any difference in the handling of my canopy or just make me look cool?AggieDave '02-------------Blue Skies and Gig'em Ags!BTHO t.u. Quote Share this post Link to post Share on other sites
cobaltdan 0 #7 December 11, 2001 shifting weight in your harness to the same side as your pulled down riser (co-steering) will give you a snap turn, ie. a very fast hook.shifting weight in your harness to the opposite side as your pulled down riser (counter-steering) will give you a broader carving hook turn. when doing a riser turn you can use weight shift to control your arc. counter steer to elongate it co steer to shorten it.sincerely,danatair Quote Share this post Link to post Share on other sites
BenW 0 #8 December 11, 2001 Dan,Good explanation that. A lightbulb blinked on! I *understand* type thing.Time for practice.Ta.Ben Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #9 December 18, 2001 Like Dan already answered (beat me to the punch!Anyway, like Dan said, most people with high wingloads do a lot of their steering with the harness, at least while they are doing their pre-swoop prep: slider stow, chest strap, undoing brakes, picking your nose, etc. ChuckMy webpage HERE Quote Share this post Link to post Share on other sites
