mobbik 0 #1 March 28, 2012 didnt know that some of them exist... like pilot chute over the nose or closed cells.... what do you do with pilot chute over the canopy? why would it happen? https://vimeo.com/39304689 Quote Share this post Link to post Share on other sites
Arvoitus 1 #2 March 28, 2012 Pilot chute over the nose is fairly common with student canopies using spring loaded PC's. I see them ~2-5 per season. Usually you don't really need to do much, just test if the canopy flies normally and is controllable and flarable. Most of the time when it happens to students they don't notice themselves at all and don't realize it until you ask them about it.Your rights end where my feelings begin. Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #3 March 28, 2012 I wouldn't be surprised if stall drills could cause this.The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
pchapman 279 #4 March 28, 2012 Yeah, heavy spring loaded PC's at the few DZ's with such PC's do fall in front of the canopy sometimes. Note that since they are spring loaded, they don't collapse so have some real drag. Worst I've seen is one dragging straight back under the center cell. That distorted the nose somewhat, but no problem for landing on a big student canopy. Sometimes happens more to very light jumpers, where I think the canopy doesn't shoot off horizontally as quickly at the end of opening, and so there's more chance for the heavy PC to drop down and happen to fall forward of the canopy. Also seen it on tandems. Big somewhat heavy drogue at the end of a long bridle. Also can fall over the front. Landed one once and seen others a couple times; no problem since the drogue is collapsed, even when it sat out near the wing tip. At least, that's what I've seen. Quote Share this post Link to post Share on other sites
SkyChimp 0 #5 April 1, 2012 That's a great video for any level of experience to watch. I wish the clarity was better but we didn't have HD back then. It's always good to review malfunctions from time to time. "Out of sight, out of mind" can be a disaster if we aren't careful. Every time I pull, I always tell myself "This is a malfunction until it proves otherwise". Does anyone else find it funny that we made a SPORT out of an EMERGENCY PROCEDURE?!?! Quote Share this post Link to post Share on other sites
Skyper 0 #6 April 1, 2012 i had this one on my student jump once. PC was not spring loaded. The canopy was about 220 sqft large and I‚m quite light-weighted. I was reading about this mal before and I could recall everything I knew during that jump. Than I did a usual controllability check and everything went fine and I landed the thing. What I've also heard is when this happens to smaller canopies it can significantly influence the controllability of the canopy and cut-away is the best, and most probably the only option. Quote Share this post Link to post Share on other sites
shropshire 0 #7 April 1, 2012 Slow down to the point of flying backwards 'could' cause the Pilotchute to fly in front of the canopy (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
crotalus01 0 #8 April 1, 2012 I have personally seen 2 cutaways because of the PC falling over the nose of the canopy. Both were on modern sport rigs with BOCs. In both cases the PC entangled some cascades/lines and distorted the shape of the canopy. As for me and my house, we will serve the LORD... Quote Share this post Link to post Share on other sites
mobbik 0 #9 April 2, 2012 lets say you open high and have the pc over the canopy but it looks like its not affecting control of your canopy in any way, so you fly it... is it possible that the pc will move, get some drag and start causing problems when your too low to deal with it.... i know...anything is possible. it would be a scary flight for sure. Quote Share this post Link to post Share on other sites
sundevil777 102 #10 April 2, 2012 Quotelets say you open high and have the pc over the canopy but it looks like its not affecting control of your canopy in any way, so you fly it... is it possible that the pc will move, get some drag and start causing problems when your too low to deal with it.... i know...anything is possible. it would be a scary flight for sure. If you're flying a moderately loaded canopy, then it should be not problem to fly it in partial to deep brakes so that the PC drag is reduced. The need to do such an accuracy type approach may be required on any off landing.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
shropshire 0 #11 April 2, 2012 Presumably the PC will have collapsed... not 'quite' so much drag then, I'd guess. (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Skyper 0 #12 April 2, 2012 QuotePresumably the PC will have collapsed... not 'quite' so much drag then, I'd guess. Shropshire, PC does not nessecerely colapse, if it's not a retractable pc there could be enough wind speed to create a drag. In my case, PC was fully loaded and had enough drag to create a V-shape in the middle of the nose of a canopy. Quote Share this post Link to post Share on other sites
mobbik 0 #13 April 2, 2012 it looks like pc over the canopy was the mal. :( http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4296312;page=unread#unread Quote Share this post Link to post Share on other sites
wetrock 0 #14 April 14, 2012 the origanal training video was done by Scot Cox. i wonder if there is a better better quality version out there ? Quote Share this post Link to post Share on other sites
waveoff5500 0 #15 April 17, 2012 this was addressed in the fjc at my dz. the remedy is a brake pump which usually fixes the issue. i have seen a cutaway by a student because of it though. might as well get rid of it while youre not paying for the repack "its just a normal day at the dropzone until its not" 1653 Quote Share this post Link to post Share on other sites
ksaylor1 0 #16 April 18, 2012 Jumping in the military with spring loaded pilot chutes, we generally attribute a pc over the nose to backsliding through pull. I've seen a lot of backsliding, and I've seen a lot of pc's over the nose. I'll stipulate that there are other causes, but personally, I think there's a correlation there. One man's opinion. Ken Quote Share this post Link to post Share on other sites
potatoman 0 #17 April 19, 2012 I put my PC over the nose the other day. 150, WL1.4, and no, I jump a non-collapsable_pc. I was playing around on top, doing complete stalls, and it jumped over, through cell 6. Control check, did some turns etc, but realised on picking up speed, more drag, more distortion. So, 1/4brakes all the way down, and landed that way with minor turns. I pay for my reserve repack, and had enough control. No issues landing though.You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
sundevil777 102 #18 April 20, 2012 QuoteI put my PC over the nose the other day. 150, WL1.4, and no, I jump a non-collapsable_pc. I was playing around on top, doing complete stalls, and it jumped over, through cell 6. Control check, did some turns etc, but realised on picking up speed, more drag, more distortion. So, 1/4brakes all the way down, and landed that way with minor turns. I pay for my reserve repack, and had enough control. No issues landing though. Are you saying you didn't flare at the end?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
potatoman 0 #19 April 20, 2012 Did flare, from the 1/4brake into a flare.You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
