micro
cross-braced canopy construction
Your pilot chute would be a good indicator of this. If the pilot chute is not directly behind the canopy and it is trailing off to one side or the other , then you are not in coordinated flight.
hard to tell this when your pc and junk is stowed in your pouch;) like a real swooper:P
The idea is to come-up with a design that reduces the overall drag: too big stabilizers too much parasite drag, too small too much induced drag...
[Cue entry of the "Stabilribs"] These were designed and implimented on the Xaos more than 3 years ago....the answer to this question.....
I guess when Joe Bennet is not building gay houses for people he gets bored, and slices his Velocity up. I wonder if it affects the openings, and other flight characteristics of the canopy. You would think that the canopy would possibly begin to slip during turns. By slipping I mean that the canopy would slide sideways during the turn. Your pilot chute would be a good indicator of this. If the pilot chute is not directly behind the canopy and it is trailing off to one side or the other , then you are not in coordinated flight.
Huh? I don't think so.....
What part don't you agree with? If it was the pilot chute part I am refering to coordinated flight like an airplane. If an airplane is not in coordinated flight then it is sliding off to one side during a turn, kind of like a drift in a car. I'm sure parachutes can experience the same same thing.
BTW it was good to see you when you here in Colorado. I hope things work out well for you in New York.
Grant
I'm sure you can put a parachute into an uncoordinated turn, the P/C may or may not be an indicator of that. I do not think the stabilizers or lack there of would have anything to do with a "sliding" of the canopy. That would be evident on videos of landings.
The stabilizers do several things:
-They trap some air from escaping to the sides during deployment making the slider descent slower.
-They reduce wingtip vorticies thus reducing drag and increasing the efficiency of the tarp.
-They offer a convenient pace to put the slider stops.
The vast majority of paragliders don't have stabilizers but then it could be argued that because the wing is so bowed with very narrow ends they do not need any. Also paragliders don't have to deal with the opening.
In any case, I don't think that over-steering (skidding) is the major reason to put stabilizers on a tarp and if I had to take I bet, removing the stabilizers from a modern x-braced tarp won't induce much over-steer but it'd definitely make a difference in opening.
I wish Joe would chime in on the subject.
for canopies that use stabilizers, such as my largish fusion 210 (as opposed these little beach towels y'all are jumping :D) does such a canopy REALLY go fast enough to make wingtip votices large enough to have a noticeable drag effect?
granted, since I'm 240-250, depending on how many chipotle burritos (yum) I eat before jumping, that fusion can start to hum, but i didn't think that such vortices would have such an effect on drag... i could be sorerly mistaken however...
I miss Lee.
And JP.
And Chris. And...
...for canopies that use stabilizers, such as my largish fusion 210 (as opposed these little beach towels y'all are jumping :D) does such a canopy REALLY go fast enough to make wingtip votices large enough to have a noticeable drag effect?
In the late 1970's I built a couple of canopies without stabilizers. After some jumps (maybe 50) I put stabilizers on. They flew better with stabs. These canopies were rectangular, about 200 sqft.
-- Jeff
My Skydiving History
The main reason behind a stabilizer is to reduce the wing tip vortices! Correct? Without stabilizers the wing tip vortices would roll around the outside edge of the canopy and make the canopy less stable and turbulent! Low aspect ratio canopies have larger wing tip vortices. On smaller high aspect ratio canopies these vortices are not eliminated because of the higher aspect ratio but are reduced significantly. They are reduced even more by making the canopy elliptical and reducing the thickness of the wing at the ends. Sub 110 elliptical canopies have very small wing tip vortices hence the reason Joe Benet didn't notice a large difference in performance when he removed them. The removal of them will reduce pack volume and most importantly reduce drag!
Later!
