kurtvert
Shutting down a crossbraced canopy
Yes. Regardless of which direction you are landing, you must still completely flare the canopy. When I rip intentional downwinders, I generally have my "landing gear" farther out in front of me, toes up and ready to slide. The key, still, is completing your flare once your feet are down and you are sliding.
Chuck
Also, let yourself sink a little more than you usually do and bend your knees. And just when the lift of the canopy is almost gone, give it an extra flare at the end to lift your body up so that you can stand on straight legs. This will pitch the canopy as much upwards as possible and will direct that last forward motion slighly upwards instead of just forwards.
Correctly executed it will look like you are pushing yourself from the ground with your legs while it is actually your canopy that is lifting you.
rgds,
Stefan
