raymod2 1 #1 March 15, 2016 Over the years there has been lots of debate over the optimal turn or how many degrees of rotation are needed to achieve maximum speed for a given wing. Competitive pro level swoopers fly anywhere from a 450 degree turn to an 810 degree turn. I've personally been using a 630 degree turn for about a year and a half. While analyzing my GPS data I have noticed that on most swoops I nearly reach my peak vertical speed after only 270 degrees of rotation. While training for Nationals yesterday I did an unplanned 270 degree turn and I was surprised to discover that this was my best run of the weekend. It's food for thought and I'm sharing my data as my contribution to the conversation. I was flying a Petra 67 with 206 lbs exit weight for a wing loading of 3.08. The elevation was 5000' MSL and the ground winds were 5-10mph (downwind). video: https://vimeo.com/159000246 plots: (attached) metrics: exited airplane: 4964 ft AGL initiated turn: 1374 ft AGL, 444 ft back, -527 ft offset max vertical speed: 440 ft AGL, 412 ft back, -18 ft offset (94.8 mph) started rollout: 357 ft AGL, 391 ft back, -27 ft offset (93.5 mph) finished rollout: 12 ft AGL, -8 ft back, -3 ft offset max total speed: 175 ft AGL, 293 ft back, -27 ft offset (102.0 mph) max horizontal speed: 34 ft AGL, 96 ft back, -7 ft offset (89.2 mph) degrees of rotation: 308 deg (right-hand) time to execute turn: 11.70 sec time during rollout: 3.92 sec time aloft during swoop: 7.26 sec entry gate speed: 84.1 mph distance to stop: 628 ft touchdown estimate: 605 ft (23.6 mph) speed carve time: ---- sec (---- mph) Quote Share this post Link to post Share on other sites
keithbar 1 #2 March 15, 2016 Entry gate speed 84 plus mph.God is great .beer is good. swoopers are crazy i have on occasion been accused of pulling low . My response. Naw I wasn't low I'm just such a big guy I look closer than I really am . Quote Share this post Link to post Share on other sites
Di0 2 #3 March 15, 2016 As a person that is learning/reading about swooping and only relatively recently decided that's what I want to do in the sport, please accept my "Fuck Yeah" by looking at those numbers. Now, as an aerospace engineer intuitively I see how on less performing wings the benefit of bigger turns are limited, since drag increases roughly like speed squared, any wing that is not very efficient (an I mean aerodynamically efficient, as in L/D) will hit its terminal speed fairly soon. I am surprised to see, though, that you seem to hit this terminal speed on a very highly loaded Petra, which is marketed as benefiting from very large turns.I'm standing on the edge With a vision in my head My body screams release me My dreams they must be fed... You're in flight. Quote Share this post Link to post Share on other sites
daffes 4 #4 March 16, 2016 Even though you can reach your terminal speed with a smaller turn, doesn't a bigger turn give you more time to think and do several small corrections during the turn without compromising the top speed? Quote Share this post Link to post Share on other sites
raymod2 1 #5 March 17, 2016 Sure, there are other considerations when choosing a turn. A bigger turn gives you more time to adjust but also more time to get pushed out of position by strong uppers. I'll say that one advantage of going from a 450 to a 630 is that the turn initiation height is not nearly as important. Quote Share this post Link to post Share on other sites
