sdctlc
TSO'ed Gear
There was a discussion about TSO'ed and non-TSO'ed gear at the DZ the other weekend. Crappy weather makes for these conversations. The questions that came up were who could legaly pack a rig for jumping in the US if it was non-TSO'ed and then who can jump the Non-TSO'ed gear.
This question was based on a jumper that is from a South Africa country and has Non-TSOed gear while traveling in the states. Additionally it went to if anybody could jump it and if a US rigger could legally pack it if they had the manuals.
Thanks,
Scott C.
After looking at the post I want to make sure it was clear: I am talking about the reserve for packing issues regarding a rigger and the reserve and container as a whole for a US jumper i.e. borowing the gear, if it's non-tso'ed.
"He who Hesitates Shall Inherit the Earth!"
Everybody loves the SIM:
Sec. 105.49 Foreign parachutists and equipment
(a) No person may conduct a parachute operation, and no pilot in command of an aircraft may allow a parachute operation to be conducted from that aircraft with an unapproved foreign parachute system unless-
(1) The parachute system is worn by a foreign parachutist who is the owner of that system.
(2) The parachute system is of a single-harness dual parachute type.
(3) The parachute system meets the civil aviation authority requirements of the foreign parachutist's country.
(4) All foreign non-approved parachutes deployed by a foreign parachutist during a parachute operation conducted under this section shall be packed as follows-
(i) The main parachute must be packed by the foreign parachutist making the next parachute jump with that parachute, a certificated parachute rigger, or any other person acceptable to the Administrator.
(ii) The reserve parachute must be packed in accordance with the foreign parachutist's civil aviation authority requirements, by a certificated parachute rigger, or any other person acceptable to the Administrator.
There you go.
Blues,
Ted
Like a giddy school girl.
There you go.
Blues,
So what if I have a residence in the UK.. but my citizenship is US. Can I jump my UK rig in the US?
:D
If you stick with the letter of the law, FAA licensed riggers can only repack FAA TSOed parachutes.
Otherwise you need a rigger with a more "flexible" rating, say a CSPA rigger. CSPA riggers can repack any reserve that is "approved" in its country of origin.
Rob Warner
CSPA Rigger A
pompous FAA Master Parachute Rigger
Rigger Rob,
That is a funny sig:)
I thought it was interpreted the way that you read it but others were thinking by the letter of the SIM a looser explanation was there.
Still an air of confusion out there on this issue I guess! Looks like the nts and bolts is agreed that depending on how you read it a US rigger can pack it but only if he is doing it so that the foreign jumper can jump it.
Thanks,
Scott C.
Scott C.
I know this is a joke, but still, I wouldn't think so, since you're not 'foreign', whatever that means. On the other hand, if you were a UK citizen, w/ a residence in the US, you could jump it.
Do you know if this is specifically stated somewhere? It doesn't seem to say that, but I have nocited recently that different parts of the FARs addressing similar things seem to contradict each other.
Blues
Ted
