ojf1982
Good Deal on PC110
Depends on the end needs of the videograghper. If getting high quality digital stills are needed... PC110. Casual flying and filming from inside the formaition stuff? Either or will do nicely. Filming on a budget? PC9. Good thing about the 9 is most the stuff for the old 5 series fits it just fine :)
The pc110 also has a flash to be used when taking still photos. If all you are going to be doing with the camera is skydiving and filming the occasional dropzone antics then I would recommend the pc9. It is the same size as the pc5 but it accepts the same batteries that the pc110 uses. Even with the small battery I have no need to recharge on the weekends. The only other thing is that according to yahoo shopping (you will probably find the best prices there, they compare hundreds of retailers) is that the pc9 has no nightshot, which is crucial for capturing boobies at night!
michael hunt (yes, that is my real name...and i've heard them all)
I don't know anyone who uses the still photo capability of their camera for skydiving purposes. The memory stick is for the still photos, as is the MPEG compression. The only time I use the still capability on my PC-5 is to rip shots off of the DV tape. Then, it doesn't matter that your still camera has megapixel resolution, because your DV tape doesn't.
Get the PC-9 if you really want a new camera, or try to find a used PC-5 on eBay.
- Dan G
I don't know if anyone mentioned this but the PC9 doesn't have the laserlink.
This is a disadvantage if you're going to be hooking the PC9 up to the video several times a day. Some of the camera guys at my DZ have had the jack plug socket wear out, thus meaning a lack of camera until fixed or replaced.
The PC110 has laserlink and can just send the video straight over the ether without being plugged up! Neat. Stops sockets wearing out too.
B
