wlie
Stroboframe anti-twist plate question
While researching on a Stroboframe, I happened to find certain anti-twist plates.
3 questions:
1) Do you use one, and if so, how necessary?
2) Which plate should I get for a Rebel X as I can't find one mentioning it.
3) Do you use one for your top-mounted camcorder as well? And what kind of camcorder are you using?
Thanks
My other ride is the relative wind.
1) Yes. For my D60. Helps a LOT to keep things aligned exactly right. If you use the cork pad, it WILL have a tendancy to twist a bit over time and so things get slightly out of alignment. Then again, I'm an alignment freek. BTW, for the D60, the "generic" anti-twist plate works just fine.
2) I don't know about the Rebel X. I had a Rebel 2000 and ordered the "generic" anti-twist plate, but for a couple of little reasons I can't exactly remember right off the top of my head, it -didn't- fit exactly right, so I went back to the cork pad.
3) I use a Bonehead dBox for my TRV style top mount video camera. I HAVE thought it might be cool to use a StroboFrame mount for a video camera, but the TRV style doesn't lend itself to doing that because of the bottom loading tape system.
quade -
Thanks Quade!
Actually I had purchased my Strobo used. It didn't have any nuts & bolts, or the cork thingy.
I had a similar experience with a camera twisting around the tripod screw. The base had one of them cork pads, and the way I fixed it was using double-sided tape in it's place.
BTW, the above mentioned was happening on a Velbon 475? tripod with the camera going sideways.
