FeFe 0 #1 October 29, 2002 Anybody works with this (or any other heavy top mount cam) combo? Any stability issues? Trying to figure out if I should stick to FlatTop or get a pricy custom-made helmet... BS Quote Share this post Link to post Share on other sites
skydog 2 #2 October 29, 2002 A friend of mine jumps with a VX 2000 and Canon stills mounted on a flat top. He has no problems as the weight of the camcorder sits further back on the plate and counter balances (slightly) the stills camera. The good thing with the Flat Top is that it can be very securely fitted which obviously helps.Journey not destination..... Quote Share this post Link to post Share on other sites
jdhill 0 #3 October 29, 2002 IMO, the FT should work just fine... I used to jump a VX1000, which is slightly smaller but heavier than the 2000. and it handled the weight and size just fine... I switched to a smaller video camera because I wanted to add a second still camera... the FT handles that fine too. No need to spend big $$$$ on a custom job. JoshAll that is necessary for the triumph of evil is that good men do nothing. - Edmund Burke Quote Share this post Link to post Share on other sites
JeanJeanie 0 #4 November 12, 2002 I just mounted another customers VX2k on a FT pro. The things you want to consider are these. 1. The extended plate so you can make a lens support u-bracket for the wide angle. You can hang the still inverted for horizoltal stills. When you want to shoot vertical you will need to put the vx next to the sharkfin, which may require a little wider top plate. Many purchase a second plate for the second setup option. 2. 1 or 2 Straps to go around the camera. 3. A bit of gasket cork or thin rubber sheeting to go under the camera to minimise slipage and act as a little shock absorber. 4. Neck excersizes........ Actually not that heavy I think the camera is 2 lbs with lens........ Great camera, great helmet, have fun! jeanie~~We are caught in an inescapable network of mutuality, tied in a single garment of destiny. Whatever affects one directly, affects all indirectly~~MLK Quote Share this post Link to post Share on other sites
FeFe 0 #5 November 12, 2002 Thanks! Quote 4. Neck excersizes........ Actually not that heavy I think the camera is 2 lbs with lens........ ...sigh... Quote Share this post Link to post Share on other sites
