ColdDuck
camera settings
After asking the same question here and searching the web I find I get really good images from my EOS500, 19/35mm Tamron using TV setting @500.
I have the lense set to 19mm, manual focus just short of infinity. This gives me good DoF for everything from tandems to FS.
I was using 200ASA at this setting, but I am not happy with the grain on big enlargements (60cmx40cm). I will start the new season shooting 100, and maybe even some 50 if I can source it.
I may even post some pics.
Buzz
If you are disappointed with the grain of 200+ you should move to slide film. I use Fuji Provia it is asa 100 and you can not tell the difference between that and Fuji Velvia which is asa 50. It will give you a little more push though.
~chachi
~chachi
Id love to use slide film, but unfortunately most of the stuff I do is for the guys from the DZ who want prints.
I am thinking about slide film for specific shoots though.
Is it easy to get prints from slide?
Buzz
Remember that as you change the film ASA other settings will have to change as well to compensate.
If you want to keep the same f-stop and depth of field that you had at an exposure of 1/500th using ASA200 film, then at ASA100 that's going to drop down to 1/250th and at ASA50, that's going to be 1/125th. This is probably too slow a shutter speed for most freefall photography.
If you want to keep the same exposure time, 1/500th, then the aperture is going to have to open up which will give you less depth of field and make focus more critical.
Trifling monograph on f-stops and exposure HERE.
quade -
I use it at 1/250th and never have a problem. Slide is the same as negative film to make prints of. I find the bonus is you spend a little more on the film but less on processing becasue you don't print the crappy shots. Just the ones you want. Plus if you have a slide scanner, turning them into digital is possible without printing either.
