MrHixxx
still camera
Killing two birds with one stone here . . .
For me, the bread and butter lens for the Canon 35mm films cameras was the 28mm lens. Small, light and compact it worked well for RW and Big-way stuff, but it also worked well, I'm told, for AFF and Tandem stuff.
When you switch over to the Canon digital line, things change a bit because fo the conversion factor. On the D60 the conversion factor is 1.6:1 so the 28mm lens acts as if it's a 45mm lens, which isn't quite wide enough for most camera flying.
On my D60 I normally shoot with a 20mm lens, which works out to the equivilent of a 32mm lens. A bit less wide than the 28mm I was used to, but more than adequate for the majority of RW stuff I shoot.
I'd LOVE to get a 14mm lens, but they're pretty damn expensive.
If you're just starting out in stills and are still shooting 35mm film I wouldn't worry about any of this because (I'm looking through the FutureCam(tm) here) in the future, the digital imagers are going to be approximately the same size as a piece of 35mm film and none of this will make any difference.
quade -
Or at least have lenses designed for the size of the CCD. Nikon just came out with one such lens but I there is not a Nikon camera I am interested in.
Yea, I heard this before, somewhere. Probably from you on here, but I'm not sure. I looked at that time for the hell of it, and the first one I found was a Sigma (?) for $799. OUCH!
The average 28 fixed I've found has been around $200-225. Guess which one I'll be getting. :S
It's your life, live it!
Karma
RB#684 "Corcho", ASK#60, Muff#3520, NCB#398, NHDZ#4, C-33989, DG#1
. . . and the first one I found was a Sigma (?) for $799.
And Sigma lenses are, uh, not exactly perfect.
The Canon 14mm lens I was talking about retails for . . . (is ya ready?!?) . . . $2199!!!
quade -
OK, let me re-state what I said....
Guess which one I will not be getting.... [:/]
Karma
