ltdiver
Maxtor HD
Imagine my complete surprise when a brand new Maxtor 3000DV 60GB HD arrived at my doorstep today! A wonderful gift from a dear friend who wanted to celebrate my birthday. :)
Now my question. I own a Power Mac G4 867 with 1.2GB MB of RAM and 60 GBHD. In looking at the directions that came with my new Maxtor external HD, it seems that it can be run with either the current unformatted HD...or I can download my OS9 and OSX and erase what they have there onboard. (I'm currently running Jaguar OS10.2).
Which is the best way to run?
(new to this external HD business, but loving it already!)
ltdiver
Don't tell me the sky's the limit when there are footprints on the moon
I just picked up a copy of computer videomaker and in an article about HDs they recommend that one drive be rederved for the OS and software and the other for media files. Some additional tips they offer are:
* Delete old media and temp files after finishing a project
*defrag your drive
*Enable write cache in the disks properties boxes(in device manager in windows) as caching can improve performance
SKYMONKEY PUBLISHING
Don't put the OS on it, or anything like that.
Then from quade (who also uses a Maxtor external 60GB HD):
Format it as a Mac OSX drive.
AndyMan....quade and I have the same OS on our computers. Is there any reason that you can add to this why I shouldn't load an OS on the external? How do you format a HD if you don't load an OS?
(not a geek...sorry) ;^)
ltdiver
I think we're having a problem of jargon.
When Quade says 'format it as a mac OSX drive', he's absolutely right.
That doesn't mean "you should put OSX on it". Putting the OS on the disk is quite different then "formatting the disk for the OS".
When you format it, you're not loading anything on it. Formatting the disk is sorta analagous to putting primer on a wall before you paint it. The primer just "prepares" the wall to accept paint (data).
it's just in this case that the primer is paint specific. Since you've got OSX brand paint, you need to use OSX primer.
To format it,
Make sure the drive is plugged into the wall, and into your mac.
Start the Disk Utility program. To get here, go to your system drive, Application folder, then Utility folder, then select Disk Utility.
The new disk should be listed. Select it. Make sure you're selecting the new disk, not your existing one. What you're about to do will distroy anything on the disk you're going to select. (dumping primer over the mona lisa)
Select the "erase" tab.
In the "volume format" box, select MAC OS Extended.
Type a descriptive name in the Name box. ("External", or "firewire").
Click the box that says "Install Max OS9 drivers". This will allow you to use the disk if you ever end up running OS9, just in case.
Click the Erase button.
A few minutes later, the drive will be formatted, and you'll be ready to go.
I'm actually not a Mac expert, I'm more a PC guru. If anyone wants to correct me, you should probably listen to them.
_Am
__
Yep, that was it. Finished formatting my new toy and transferring the video and other media files to it. Works like a champ!
Thanks everyone for your help. Hope to return the favor some day. :^)
ltdiver
