skydog
Splicing Remote Control
Ok, IF you have a Conceptus tongue switch WITH a 2.5mm plug, then do NOTHING to that.
On the remote switch for the 10D, cut that in in half and solder on a 2.5mm SOCKET (shield and red). Then when the tongue switch fails, and at some point it will (probably when you're on a million dollar shot load with a 5 minute call), then all you have to do is unplug the old tongue switch and plug in the backup you have in your gear bag.
Make sense?
quade -
Make sense?
Been to the shop got the socket.....and now !!!!!!
After chopping the wire, 3 attempts at soldering the wires............. success.
Thanks for your help Quade.
Bryn
Journey not destination.....
*BUMP*
all I could find at radioshack was something called '2.5mm phone jack' it IS a 2.5 mm female pug, but has exposed back with like, 3 prongs and a little thingy. ya think it would it be ok to start hookin' wires up all over the place and testing the camera with it?
Vid
"stons fal, evrysing fals, but doesnt on purpos change its flite pas an positioning..."
Sorry to take so long to reply.
I got a stereo female plug. The inside had two connectors and a long T shaped strip.
I soldered the red and white together and put that to one of the small connectors on the base. The shield copper wire I connected to the T-bar.
When i tried other combinations the camera would fire but not auto focus.
Top Tip : Make sure you try in AF mode before soldering all the wires and setting up your helmet DOH!!!
Anything else just give me a shout.
Bryn
How many wires inside the remote switch cable??. I've got the RS-80N3 and before I chop I'm just trying to get more info.
I've got the tongue switch with the 2.5 plug on the end. And have a 2.5 socket coming.
What wires did you use from the remote cable. Are they coloured.
thanks eddie.
Which is why I said, shield & red and MANUAL focus.
White is the "half press" and is kind of superfluous for my purposes. I don't need no auto-focus. ;) As a matter of fact, I specifically don't want it, but to each his own.
quade -
I don't mean to drag this topic on and on, but how have you wired up your female socket on your canon cable to be able to switch from AF to MF. I thought It would have to be one or the other.
I think if you have the regular plug on your biteswitch it won´t work, but I got the stereo version on purpose, so I can use all 3 wires (and also can connect the remote together again BTW). So now I can set the switch on the lens to manual or autofocus as usual.
I don´t really need the autofocus for skydiving, but I liked the idea of being able to use the (expensive) remote again too...
ciel bleu,
Saskia
To be more accurate, the camera will attempt to auto-focus before firing no matter how long that takes. Depending on the situation, it may not achieve a good focus in the time frame wherein the event you wanted to capture is still occurring. So, you may actually miss the moment you had originally intended on photographing.
Probably really useful in some situations and really disastrous in others. Use with caution. Your mileage may vary.
quade -
Absolutely. But I find if I set the focus point up that I intend to use, and frame with it where I want the camera to focus, I have gotten some good results.
I have busted on others.
I would never use autofocus (at this point in my ability) if I was getting paid to get a shot. But it can produce some neat results using aperature priority and autofocus to limit depth of field.
That's correct. With the lens set to manual it will not attempt to autofocus and the shutter will trip immediately if you have it set to shutter priority.
I'm having some success with autofocus, though. Here's a couple I shot this afternoon with fill flash at 500th on autofocus.
JP,
Forgive me if I've missed the thread....but are you using your digital for student pics now? i.e. Tandem?
And if so, how are you handling this differently than those that are using 35mm negatives in your video pool? Are the customers accepting of this new format?
ltdiver
Don't tell me the sky's the limit when there are footprints on the moon
