lister55
Problem sighting in video
I just recently swapped from my my "home made" camera helmet to the 2k composites FF2. I am using a cross ring sight and on the ground the video, still and sight all match perfectly. However when I get in the air, I am still looking through the center of the sight, but the images are always offset to the top right. I never had this problem untill I switched helmets. I have also heard some rumors that others have been having the same issue. Does any one know of this or have any advice?
I have done exactly as your document recomends. But no matter if I set up at a short or long distance it just seems to be incorrect in the air. I know the sight should account for shifting of the helmet, so I can not figure this one out. i have had several other video guys try to help me sight this in properly, but it makes no difference. Starting to get frustrated as I cant figure this one out.
Have you tried just not using a sight at all? It seems as though you're not looking through the site properly. I use a dot on my glasses and have great luck, and it's easier for me to line up the dot.
Many freefliers don't use sights unless it's competetion or important jumps.
Just a suggestion
______________________________________________
- Does this small canopy make my balls look big? - J. Hayes -
To answer all of the questions quickly... Yes I am sure I am not bumping it. Yes I have the sight on my dominate eye. And no I havent trried without the sight. Going without is not my problem. I used the same sight on my previous helmet with no problem for ~200 jumps. This is why I dont understand what is going on. Any insight on this problem is welcome.
