Squeak 17 #1 April 21, 2004 OK I'm using movie maker (cause it's really easy) and I want to take out the freefall sound and replace it with music. I know how to add music but can I delete or reduce in volume the freefall sound (wind noise)???You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
IanHarrop 42 #2 April 21, 2004 Top menu under Tools, click on Audio Levels. Slide the control away from "Audio from Video". Depending onwhat tool bars you can see this is also the left most thing you can click on above hte movie timeline"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
Jumpmunki 0 #3 April 21, 2004 just get premier it's dead easy and a much more indepth editing prog that no doubt you already know about, just frightened to learn how to use it Quote Share this post Link to post Share on other sites
AggieDave 6 #4 April 21, 2004 Quotejust frightened to learn how to use it Meh. I've started using it and found it to be fairly straight forward. As long as you have an idea of what you want to do, its pretty simple.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
Squeak 17 #5 April 22, 2004 QuoteQuotejust frightened to learn how to use it Meh. I've started using it and found it to be fairly straight forward. As long as you have an idea of what you want to do, its pretty simple. That should be prfect for me then, I'm pretty simpleYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
SpinDoctor 0 #6 April 27, 2004 Drag the clip into the timeline - the 'sound waves' should appear in the Audio timeline. Right click on the audio clip(s) in question and select the 'Mute' option from the menu. BTW. I am using MovieMaker ver. 2.0.3312.0 with Windows XP----------------------- Connextion: British 8 Way Team www.bodyflight.co.uk ----------------------- Quote Share this post Link to post Share on other sites
ManBird 0 #7 April 29, 2004 Use Movie Maker 2 (I actually stopped using Premiere in lieu of this app!). http://www.microsoft.com/moviemaker/. FAR better than the first release. Right click on "audio" and select "Mute". Done."¯"`-._.-¯) ManBird (¯-._.-´"¯" Click Quote Share this post Link to post Share on other sites
