StevePhelps
HELP!! video turned GREEN!!
Help! I just did a tandem video tonight and about pull time the video turned green! Like a white out, but green. It stayed green during the filming of my descent.. I film a 360 before I shut it off. When I turned in on for the landing it was okay but went green again as they landed.
I filmed a few seconds of other footage over the green part to see if it was the tape. That footage was fine.
It has to be the camera (Sony TRV 19) Any clues???
I need a camera for this weekend -- I may have to buy another one. Many of Aultimate Electronics' cameras are on sale.. What would be a good one?
Do a couple of frame grabs and post them.
Since I assume you're familiar with what NightShot looks like, I'm also going to assume that's NOT it, but my guess right now is that you have a loose connection internally.
Yes, the camera will have to go into the shop.
quade -
OH! That -IS- NightShot!
You have something wrong with the switch -- maybe loose. You -might- be able to wiggle-jiggle it and use some gaff tape on it to get it to stop doing that, but if not it'll still have to go into the shop, but should be an easy fix for them.
quade -
Maybe it's the combination of nightshot and bright sunlight that's overloading your CCD and making it really green.
It's happened on a couple of handicam videos. The button gets turned on as you're putting the camera in the pouch...
Arching is overrated - Marlies
The outer switch would be impossible to turn on/off without knowing. It was definetly off --- but when checking the inner menu I discovered the N.S. was clicked "on" -- I have no clue how THAT happened!! I put it on "off" and I will hope for the best Saturday. Most likely will make a test jump early that AM
I'm pretty sure (99.99%) that what you're looking at is an intermittent (sometimes on, sometimes off) NightShot switch issue.
When NightShot is on in daylight, it looks -exactly- like what your clip showed. Wait until tomorrow during the daylight hours and check it out yourself -- you'll see what I mean.
It's possible, that you bumped the switch just a little while puttting in its bracket or maybe a piece of foam was rubbing up against it or anyone of a dozen reasons. Take a good hard look at the switch.
Oh and as to the menu setting for the NightShot light . . . all that does is turn on a couple of IR LEDs on the front of your camera when the NightShot switch is on. The menu setting -shouldn't- have a caused your problem, but turning it OFF couldn't hurt.
quade -
The techies at Ultimate Electronics where I bought the camera say it is the N.S. as well, But the switch is okay -- They "figure" the wind may have caused it?? Whuffos answer to all camera problems when skydiving.
However, they may be right, but how do I fix? Gaffers tape? They don't make a condom to fit the TRV 19.
Their main man thinks it was a fluke. Easy to say when you aren't the one charging someone. They have a PC 101 for $750 -- Should I buy it?
Ask them how much time is on the drum. This will tell you about how long the camera has been in use. If it seems like a low timer, I'd say, go for it.
(PC750)
Stuck nightshot switch...just make sure to double check. Mybe it was in between "clicks". If ya want to tape it.OK
http://www.curtisglennphotography.com
