kallend 2,027 #1 November 3, 2004 OK, so I installed Premiere 6.5 some long time ago and everything was fine. Then I made a PAL DVD for my sister in the UK, and I clicked on the PAL box in the project setup. After it was done I clicked back on the NTSC box. From that time on everything I capture has been incorrectly interlaced, and I have to turn off interlacing in the "clip" menu video option to make it look right. So: why did it get screwed up by going from NTSC to PAL and back, and What do I do to get it back like it was so I don't have to do it manually each time?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
Zoter 0 #2 November 3, 2004 I use Prem.Pro 1.5....with no prior 6.5 experience.....this may work in 6.5 , not sure.. Hers the path to set the defaults to NTSC Open Premiere.....'EDIT'.....'PREFERENCES'....'DEVICE CONTROL'.....'VIDEO STANDARD' ....then choose NTSC and then 're' save the project Hope it works.....file incompatibility probs when editing suck... Quote Share this post Link to post Share on other sites
kallend 2,027 #3 November 4, 2004 QuoteI use Prem.Pro 1.5....with no prior 6.5 experience.....this may work in 6.5 , not sure.. Hers the path to set the defaults to NTSC Open Premiere.....'EDIT'.....'PREFERENCES'....'DEVICE CONTROL'.....'VIDEO STANDARD' ....then choose NTSC and then 're' save the project Hope it works.....file incompatibility probs when editing suck... Tried that. It defaults to NTSC OK but the interlacing is still messed up until I explicitly fix it for each new clip captured.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
nacmacfeegle 0 #4 November 4, 2004 I can't help you John, but someone here may be able to... http://www.dvdoctor.net/cgi-bin/ultimatebb.cgi?category=1-------------------- He who receives an idea from me, receives instruction himself without lessening mine; as he who lights his taper at mine, receives light without darkening me. Thomas Jefferson Quote Share this post Link to post Share on other sites
DJL 235 #5 November 5, 2004 QuoteNTSC to PAL A quick aside, what do these acronyms stand for?"I encourage all awesome dangerous behavior." - Jeffro Fincher Quote Share this post Link to post Share on other sites
alain 0 #6 November 5, 2004 strait from google: NTSC stands for National Television System Committee http://archive.ncsa.uiuc.edu/SCMS/training/general/details/ntsc.html PAL stands for Phase Alternation by Line http://archive.ncsa.uiuc.edu/SCMS/training/general/details/pal.html Quote Share this post Link to post Share on other sites
el_chester 4 #7 November 5, 2004 I work in video doing post-production, and regardless of the official acronym, this is what most of us call it: NTSC - never the same colors NTSC - never twice same color it is an old standard which was developed in the analog tv days, and still is the most used standard even when it is by no means the best standard (kind of like microsft operating systems... ) -- Be careful giving advice. Wise men don't need it, and fools won't heed it. Quote Share this post Link to post Share on other sites
