cvfd1399 0 #1 November 9, 2004 Ok first this semi-junk camera is only for ground filming. Now that we got all that out of the way the camera is a Sharp VL-nz50u with a 27mm lens filter. I am looking for a lens that will give it that wide, sporty look to it while filming swoopers and other stuff. I know it is a cheap brand that uses a not as popular 27mm ring size, but there has to be something out there for it that will work. I found this, but I am not sure if it will fit http://www.adorama.com/RXDVR5000.html It says that it has 37mm mounting threads and includes. 3-adapter rings 27mm/30mm/30.5mm included. I also found this on e-bay E-bay and this E-bay2 do you think this would give a ok quality? Also can you put a circular polarizer in front of a wide angle lens to help with sky/cloud/jumper contrast? I am almost clueless as to what size angle to get for good ground shots, so if anyone can find one that they think will look good in a 27mm thread please post the link. I am so thankful for the help in advance. Quote Share this post Link to post Share on other sites
cvfd1399 0 #2 November 11, 2004 I ended up getting a Titanium I.R. Series Super Wide 0.42X AF high resolution video wide angle. We will see how it goes in a few days. Quote Share this post Link to post Share on other sites
