aerialcameraman 0 #1 December 2, 2004 How do you guys mount your d-box to a flat top pro? I am getting a pc 109 and am getting a d box for it but was woundering if you guys screw both the d-box down and use a tripod screw for the camera in the d box. Pics if possible would be greatly appreciated. Quote Share this post Link to post Share on other sites
TALONSKY 0 #2 December 2, 2004 I am not sure if this will help but on my FTP, I made my own box for my PC105. I attached it to the top and the PC105 is attached using the 1/4-20 on the bottom of it. Kirk Quote Share this post Link to post Share on other sites
vdschoor 0 #3 December 2, 2004 QuoteHow do you guys mount your d-box to a flat top pro? I am getting a pc 109 and am getting a d box for it but was woundering if you guys screw both the d-box down and use a tripod screw for the camera in the d box. Pics if possible would be greatly appreciated. I have the d-box screwed to the top plate (TRV17, not a PC style one) and you just put the camera in the box, close it and you're done! No extra screws for the camera inside the box, it's kept in place by the box and the padding inside the box. Iwan Quote Share this post Link to post Share on other sites
r2hubert 0 #4 December 2, 2004 Have you seen any DBox for the Sony HC85 not the trv80 ? -- Renaud SMA #9 "Mind is like parachute. It only functions when it's open." Quote Share this post Link to post Share on other sites
vdschoor 0 #5 December 2, 2004 QuoteHave you seen any DBox for the Sony HC85 not the trv80 ? I have not, but contact hottamaly (here on dz.com) or call Bonehead Composites to find out. They might just be working on those or already have them. They are not advertised on the website yet.. but you never know! Iwan Quote Share this post Link to post Share on other sites
r2hubert 0 #6 December 2, 2004 I wonder if I could trade my TRV box for the new HC -- Renaud SMA #9 "Mind is like parachute. It only functions when it's open." Quote Share this post Link to post Share on other sites
aerialcameraman 0 #7 December 2, 2004 The pc style d box has the hard red cord that closes the top of the box to keep the camera in. Has anybody had any problems with the camera moving causing it to tape the jump out of sight and having the tape gitter or flutter. Just asking or does it close up really tight so once the camera is in place it does not move. Also once you sight it in and remove the camera from the box and place it back in will you have to resight the camera or will it be sighted in still. Quote Share this post Link to post Share on other sites
AndyMan 7 #8 December 2, 2004 I have a PC120 in the dbox with the red hinge cable... The camera does not move. As for wiggle, once I plug in the cam-eye, the the camera no longer wiggles. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
jcd11235 0 #9 December 5, 2004 I have a PC5 in a BH DBox, with no tripod screw. It shuts very tight, and I have never had a problem with it moving.Math tutoring available. Only $6! per hour! First lesson: Factorials! Quote Share this post Link to post Share on other sites
aerialcameraman 0 #10 February 6, 2005 Does anyone have a picture of where they placed the foam inside the box or the best position to place the foam so the pc109 will not move.. Quote Share this post Link to post Share on other sites
skygod7777 0 #11 February 6, 2005 QuoteDoes anyone have a picture of where they placed the foam inside the box or the best position to place the foam so the pc109 will not move.. call jason, that's what he has. later Quote Share this post Link to post Share on other sites
Shivon 0 #12 February 7, 2005 I have set my trv d box up on a FT narrow the same way as Iwan has, and have never had any problems with it. The camera sits snug, and can be taken out and put back in without worrying my sighting (have not had problems yet). Regards the foam in the box, I find that the foam stuck to the roof of the box deteroriates first, but taking the door off completely and rotating it 180 degrees after about 150 jumps keeps the fit nice and snug. After 300 jumps I replace the foam completely (and start the cycle again). The camera really is quite tight once the door is closed and the red cable is routed. Quote Share this post Link to post Share on other sites
aerialcameraman 0 #13 February 7, 2005 Where do you pick up that type of foam with the really sticky glue on the back. I have some foam but it is not all that sticky and falls off. Can you get that foam from your local hardware store. Quote Share this post Link to post Share on other sites
velocityphoto 0 #14 February 8, 2005 go to this site (www.rimworldvideo.com) These are the mounts to have, he makes each mount custom to your camera and special needs.. Lonnie A friend will bail you out of jail , a REAL friend will be sitting next to you in the cell slapping your hand saying "DUDE THAT WAS AWSUM " ................ Quote Share this post Link to post Share on other sites
Shivon 0 #15 February 9, 2005 I got mine from a fishtank supplier (sits on a glass ledge around the top, and then the lid of the fishtank sits on the foam). You may want to get onto bonehead though and see if they can send you some. Quote Share this post Link to post Share on other sites
nacmacfeegle 0 #16 February 9, 2005 Kayak stores will have some.. for example... http://www.kayakoutfitting.com/foam/neo.html Google for 'self adhesive neoprene'-------------------- He who receives an idea from me, receives instruction himself without lessening mine; as he who lights his taper at mine, receives light without darkening me. Thomas Jefferson Quote Share this post Link to post Share on other sites
turtlespeed 226 #17 February 9, 2005 Can't find my pics - I know they are here somewhere - but I have a Dbox/Still Combo on a FTP. Makes it a little annoying when doing interviews for fades and stuff - but the damage/protection factor outweighs the annoyance ratio.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
