jont 0 #1 June 9, 2005 Hi all, hope someone can help me A copy of Premiere 7.0 Standard (not Pro) came with my new VAIO laptop. I am just experimenting with it. Have dumped a load of footage of a 4-way training camp into it, and have edited out all the unwanted stuff. Now want to burn the result onto a DVD. The online pdf manual says I should go File/Export/Export to DVD - but when I try I am not offered that option, only export to tape, export to various video formats, etc. The laptop does have a DVD burner on board. Is it because I have Standard not Pro that I'm not offered the option? The manual specifies elsewhere whenever an option is Pro-specific, and it doesn't here. Anyone else used Premiere Standad to output to DVD? Any idea what the issue is here? All suggestions gratefully recieved. Jon T Quote Share this post Link to post Share on other sites
freefallcrab 0 #2 June 9, 2005 Jon I went through he same pain. I am not at Weston this weekend but will be there next weekend and we can talk about it then although I am sure you will get better advice through here. I hook up an external DVD burner to my laptop and it is fine albeit very slow to render and burn (using Nero). Use your wings Johnny.... Quote Share this post Link to post Share on other sites
EricTheRed 0 #3 June 9, 2005 I do believe that it is the version of Premire that you have. One of Adobe's sneaky ways of forcing you to upgrade. You can export to tape and use a standalone DVD recorder or export to a DV AVI file and then use something else to record the DVD. Or find a copy of Premire Pro...illegible usually Quote Share this post Link to post Share on other sites
newshooter12 0 #4 June 10, 2005 in my experience with NLEs with an internal DVD burner you have to convert the video to MPEG-2 either with the edit software or export to one such as Sorensen Squeeze. then once the coversion is complete open up DVD authoring software such as Nero, or DVD-it, etc... create the DVD layout & then burn it to disc. correct me if i'm wrong... you should be able to "export to tape" with a camera, VTR, or external "stand alone" DVD recorder. check out the other thread on DVD burning in this forum. matt Quote Share this post Link to post Share on other sites
