Chrissay 0 #1 April 4, 2006 I'm hoping that someone can help me out. My Epson R200 won't print black anymore. I changed the black cartridge just in case and swabbed with a q-tip the contact points of the cartridge in the printer. Anyone have any suggestions as to what the problem might be? thanks! Quote Share this post Link to post Share on other sites
freefalle 0 #2 April 4, 2006 Chrissay, I've had that problem with a printer in the past, if you have replaced the printer cartridges and cleaned or replaced the printer head try disconnecting the printer, go into your computer software and delete the printer then reinstall it. Im no computer guru but its possible some of the drivers may not be functioning properly. I dont really know what your specific printers problem is but that worked for me. Its worth a shot. Quote Share this post Link to post Share on other sites
ltdiver 3 #3 April 4, 2006 I did that once, then 'discovered' that I'd forgotten to take that little plastic strip off the new cartridge before installing it! ltdiver Don't tell me the sky's the limit when there are footprints on the moon Quote Share this post Link to post Share on other sites
howardwhite 6 #4 April 4, 2006 Quote I did that once, then 'discovered' that I'd forgotten to take that little plastic strip off the new cartridge before installing it! ltdiver The R200 cartridges don't have little plastic strips that need to be stripped. HW Quote Share this post Link to post Share on other sites
